Sennheiser lav's adapter at DVinfo.net
Old March 30th, 2003, 11:37 AM   #1
My Sennheiser lav's need an adapter to XLR. Anyone have a suggestion besides the $40 solution I see on B&H. Radio Shack maybe?
I was hoping for a one cord/wire solution but given the money I've spent $40 seems high. Especially since I have to buy for both sets of mic/rec's.
Thanks in advance.
Mark
Green Novice turning Yellow Pro
Soon to be Ripe - So stand back!
Mark Richman is offline   Reply With Quote
Old March 30th, 2003, 11:59 AM   #2
I didn't find any decent solutions on the cheap. I ended up with the $40 one. I make myself feel better by saying "I don't want cheap cables anyway, they could add noise to my audio feed." It helps a little.
This is the way the world ends.
Brian Pink is offline   Reply With Quote
Old March 30th, 2003, 07:00 PM   #3
You can always make your own adapter cables. Or cut the plug off the end of the Senn and put a XLR on. If you intend to put the microphones at the end of a long cable, then you would do well to put an isolation transformer near the microphone so you can drive the long cable with a balanced signal.
Mike Rehmus
Mike Rehmus is offline   Reply
