DVF-L700 & DVF-El100 compatibil​ity being used as viewfinders on Sony F65 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old August 14th, 2013, 01:23 PM   #1
I'm sure Sony has provided an adapter cable that can be used to allow one or both of these cool viewfinders the DVF-L700 or DVF-El100 which are 26 pin connector units to be plugged into the F65 20 pin viewfinder connector.
I don't want to give up my two SDI outputs because they are being used for different purposes. I don't want them used for a viewfinder. Does anyone know what part# for the adapter cable would be?
I would hate to see Sony develop cool new viewfinders and other very useful options for the new F5/F55 camcorders at the expense of not providing them for the F65.
The 7" 1080p viewfinder is a natural for the F65
Douglas Call is offline   Reply With Quote
Old August 15th, 2013, 10:43 AM   #2
Re: DVF-L700 & DVF-El100 compatibil​ity being used as viewfinders on Sony F65
As I understand it, F65 owners can take their cameras in and get the new EVF port installed.
I don't think it was a trivial thing, much more than an adapter cable, as the new 5/55 port is digital based while the original F65 EVF was analog. I believe an internal board int he camera is replaced.
This upgrade was always described as being for the OLED finder, but I'd be interested in knowing if it can drive the 7" monitor or the LCD finder as well.
My Work: nateweaver.net
Old August 16th, 2013, 04:47 PM   #3
I'm getting ready to send our F65 in for the Version 3.0 upgrade. I'm going find out in advance from the Sony DMPC if that hardware update allows me to connect the Sony DVF-L700 7" Full HD Monitor. If so that will be awesome. the new viewfinder option doesn't really do much for me. Otherwise I'd be stuck with the 7" host of standard 3rd party SDI/HDMI plug in monitors. I think someone is coming out with a 3rd party 720p 7" monitor soon.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
