Firmware Version 2 and Optical Low Pass Filter at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old September 19th, 2013, 01:24 AM   #1
Just a brief update from IBC. Firmware version 2.0 will be released at the end of September and will include the high speed raw shooting modes, 2K at up to 240fps. In addition there will be the addition of waveform, vectorscope and histogram.
The Audio button and File bottom on the side panel will be become active. The audio button adding 2 pages of Audio control functions including quick switching for each channel between manual and auto as well as manual level control via the large menu knob. The file button gives quick access to load and save a number of "all files" so you can quickly switch between different camera setups.
Further new features are full support for the Fujinon Cabrio lens (the lens will need a firmware update too) with zoom control and rec start/stop. Support for Sony's new LA-FZB1 (5000 Euro approx) and FZB2 (9000 Euro approx) lens adapters for B4 lenses.
This is a very significant update for the cameras and includes a lot of other smaller new features.
When shooting 2K the camera uses the full sensor, but it is read in a different way, one that create larger "virtual" pixels (my words, not Sony's). This means that as the sensor is now operating as a 2K sensor that the factory fitted 4K optical low pass filter (OLPF) is not optimum for controlling aliasing and moire. Sony will be offering (for sale) a drop in replacement 2K OLPF. The 2K OLPF will control aliasing and moire at 2Kas well as providing a softer look at 4K for those wanting this. It is almost essential for the 2K high speed modes and gives a smoother look at 4K that works well for beauty, cosmetic, period drama and similar projects.
Version 3 Firmware will be released at the end of year, probably a little after Christmas. Version 3 will add the compressed XAVC high speed modes as well as a new feature which is a 2K super 16mm crop mode. The S16 crop mode will allow you to use S16 PL mount lenses or B4 zoom lenses using the MTF FZ-B4 adapter without the 2x extender and only a 0.3 stop light loss. Also included will be AES/EBU digital audio and other features not listed here.
Old September 25th, 2013, 11:36 AM   #2
Austinite
Sony Announces B4 Mount to FZ Mount Adapter
The LA-FZB2 is a B4 to FZ Mount Adapter for the F5/55.
I wonder if you can only use lenses with a 2X extender engaged. The ND filter wheel looks good. Broadcasters will definitely recognize that as having a familiar look and hopefully feel.
News page @omagebradcast below:
Omega - News - Sony - Sony Announces B4 Mount to FZ Mount Adapter
Phil Goetz is offline   Reply With Quote
Old September 26th, 2013, 07:43 AM   #3
Re: Firmware Version 2 and Optical Low Pass Filter
Thanks Alister great info.
Will the 2K OLPF be needed for both the 5 and 55?
Paul Cronin
www.paulcroninstudios.com
Paul Cronin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
