Why does the EX encode 1440x1080 24P like this? at DVinfo.net
Old September 10th, 2007, 03:02 PM   #1
Newbie question.
Judging by the Australian literature the SP mode encodes the 23.98 within a interlaced stream that requires pulldown?
Why does the camera do this when presumably the 1920x1080p24 mode is recorded natively to the SxS cards.
Is it to do with getting the stuff off over Firewire?
Paul Ramsbottom is offline   Reply With Quote
Old September 10th, 2007, 07:12 PM   #2
Images: 1
It uses progressive segmented frame which does not require pulldown. The progressive image is broken into two fields with no time differential so they can pass through the same signal chain that handles interlaced material. On output, the two fields are re-assembled into a true progressive frame.
-gb-
Old September 10th, 2007, 08:13 PM   #3
Two questions:
1. According to the brochure, there is no 24p in SP mode.
2. The brochure lists PAL and NTSC as separate modes. Am I safe to assume that the camera released in the U.S. is going to be identical to the camrera released in Austrlia? I ask because The V1U had 24p but the V1P didn't. I'm wondering whether the Austrlian (or PAL in general) release of this camera will remove the 24p capability and therefore the CineAlta badge?
Attached is the part from the brochure that addresses this.
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply With Quote
Old September 10th, 2007, 09:02 PM   #4
What th Aussie brochure says (in multiple places) is:
"*In 1440 x 1080/23.98P (SP) mode, images are handled as 23.98P and
recorded as 59.94i signals through means of 2-3 pull-down."
So... I guess (and the Sony copy could have been worded better):
1. Full XDCAM HD 1080p24 1920x1080 is recorded as the progressive segmented frame. No pulldown required and will need to be transfered to computer visa card or SDI.
2. SP 1080p24 1440x1080 is recorded in an interlaced stream and will require pulldown (but can be transferred to computer by Firewire). Like the V1U
Old September 10th, 2007, 09:15 PM   #5
Really? I guess I'm behind the 8 ball then. Is there a link somewhere to this Australian brochure?
When you say 1920x1080 24p must be captured via card or SDI, I assume you are referring to the SxS card? Or do you mean something else?
John Hewat
Old September 10th, 2007, 09:22 PM   #6
John,
The brochure download is in the sticky at the head of this forum.
Vaughan
Vaughan Wood is offline   Reply With Quote
Old September 10th, 2007, 09:43 PM   #7
Originally Posted by Vaughan Wood View Post
John,
Vaughan
That's the brochure I saw. It does not say in the specs at the end that the recording modes include 1920x1080 24p in SD mode.
John Hewat
Old September 10th, 2007, 10:48 PM   #8
Images: 1
I'll have another look at that brochure. I notice they are labeling HD modes as PAL and NTSC which is bogus. In HD, there is no PAL or NTSC, only different frame rates for proper sync with lighting based on power line frequency.
EDIT: Just re-read it and it does indeed look like they are using pulldown to 60i. That's a bit of a shame because it doesn't increase record capacity when shooting 24P.
-gb-
Old September 10th, 2007, 11:40 PM   #9
agre 100% about the non "native" frame recording (ie using pulldown) and its lack of efficiency.
As for teh PAL model shooting 24p (as opposed to 25p) the transport stream itself needs to be able to handle the math.. u cant get 25p from 60i unless ur messing with it in post.
One other thing, and i believe this is the fundamental reason why 25p is not supported, is due to the fact that BluePrint (the BluRay MPG standard) does NOT support 25p, it only supports 24p. Also, 1440x1080 is NOT supported either, in turn scaling up or a shift in the Aspect is required.
Peter Jefferson is offline   Reply With Quote
Old September 11th, 2007, 04:44 AM   #10
Not quite - progressive segmented frame ("psf") is true progressive images delivered in an interlace fashion. So whereas for a true progressive image lines would be delivered 1,2,3,4 etc..... then next frame, for psf *THE SAME LINES* are delivered 1,3,5 etc, ..... next FIELD 2,4,6 etc....., then next frame.
Consequently (unlike interlace) conversion between psf and progressive is simply a matter of reordering lines - not scaling or deinterlacing etc.
For 23.98p, the psf variant is delivered over 60i (so needs pulldown), whereas for 25p, 25psf is delivered over 50i, so no pulldown is needed.
The reasoning is that to a display it presents the same appearance as an interlace signal, and hence is compatible. Better displays should detect that it is psf, not interlace, and treat it accordingly.
Old September 11th, 2007, 06:52 AM   #11
Can I get some clarification on this point?
It's confused the heck out of me. Is it possible to shoot 24p (or 25p) 1920x1080 footage to an SxS card and then simply drag it to the PC as a file?
I don't need to capture live via SDI do I?
John Hewat
Old September 11th, 2007, 07:15 AM   #12
Yeah... With my V1E 25PsF, I didn't find any such "better display"; unfortunately all HDTVs I tried, treated the signal as regular 1080i and de-interlaced it, resulting in heavy line twitter. The only way to play it back properly has been so far using a software MPEG player with deinterlaced forced off.
Do you know of any "better display" device model that will recognize the 25PsF properly?
Old September 11th, 2007, 10:36 AM   #13
In short - no. But I'd expect them to be the more expensive ones!
Old September 11th, 2007, 10:46 AM   #14
<snip> Is it possible to shoot 24p (or 25p) 1920x1080 footage to an SxS card and then simply drag it to the PC as a file?
Yes.
Old September 11th, 2007, 11:37 AM   #15
Images: 1
Here's a good document that explains all this stuff.
http://www.leitch.com/resources/whit.../Whatis24P.pdf
-gb-
Greg Boston is offline   Reply
