Hi Peter & David,
Link correction: www.dvb.org In the UK this is how we receive DTT in SD PAL form (Freeview etc...) - soon to include HD in certain areas by 2009/2010, rolling out to most areas by 2012 for the London Olympics (at which point analogue broadcasts will have been switched off & fading away into space for the last time). Sorry for going a little off thread! |
And just to clearify, DVB is a transmission format, while Pal or NTSC are signal formats, as are all the HD variants. |
All 24p formats should be under Hollywood Area in the menus :)
As stated before there is a Country menu for NTSC Area (60Hz) and PAL Area (50Hz). 24p should not be in any of those in my opinion. But if there where to be no Area selection the format menu would not fit the lcd screen and need to scroll down (It does already need to scroll down when set to NTSC Area but only one step). I would like to see a firmware update using this menu. Format: >Progressive HQ 720p24 HQ 720p25 HQ 720p30 HQ 720p50 HQ 720p60 SP 1080p24 HQ 1080p24 HQ 1080p25 HQ 1080p30 >Interlaced SP 1080i50 SP 1080i60 HQ 1080i50 HQ 1080i60 |
Note that we have two 24p modes in this camera:
- native 24p (HQ) -24PsF with pulldown inside 60i (SP) This is why it beats me why there is no 25/30PsF in SP, within the 50i/60i respectively. |
This may be a meander off-thread again, but I have a Blu-ray version of the landmark "Planet Earth" series (BBC box-set) which appears to be 24p within a 1080i60 format (ie, with 3:2 pulldown).
I have to say it is noticably jerkier than I recall the SD Tx to have been, still watchable, just a little disappointing as the original 25p(in 50i) has been converted to fit into a 60Hz format. A little unexpected for a UK-originated production, no...? Well perhaps, but I guess this format was chosen as it is universally viewable across most territories (the US being a large potential market for it) - thus avoiding the need to produce a disc each for the 50Hz and 60Hz markets. I am worried that for this reason, there are precedents being set that will result in HD @50Hz becoming a broadcast-only format, ie. mass-produced Blu-ray/HD-DVDs will only come in 60Hz flavours (24p/30p/60i) as it is currently the most 'universal' standard. If this happens then player manufacturers may drop support for 50Hz playback altogether (if they ever had it) in order to trim the RRP down to where it needs to be. In this case, the question is; does shooting in a 50Hz flavour of HD really mean I am future-proofing, or is the only 'safe' choice a 60Hz flavour ? |
Nevertheless to differentiate only between "progressive" and "interlaced" frame rates makes absolutely sense in world where it should be paramount tear down borders (in many respects). |
I had discussion with technical heads at Czech TV and basically, I am told that in PAL area these days, all tv and most if not all feature films are shot at 25 fps to avoid the 4% speed change that used to be done to films when they were broadcast on PAL tv. So, there is essentially no need for 24 fps in (some) PAL countries. Also, if one wants to shoot in 24 fps (in PAL world), I don't see a reason why not use one of the 'so-called' NTSC settings, which as we established are not NTSC anyway because they are simply HD with 'NTSC' frame/scan rate. Simply switching to 1080p at 24 fps should be all that needs to be done. Shouldn't it?
Sorry of being ignorant on this, but is this camera PAL and NTSC? If I buy the camera in New York will it be suitable for Europe (PAL areas)? The video out can be switchable to PA or NTSC?
Stelios |
All my 25p cameras have shutter speeds that go down to 1/25. The EX1 when in 25p only goes to 1/33 and the overcranking is 60 fps rather than 50fps. Both of these are setting for 30p cameras. How come?
| All times are GMT -6. The time now is 07:03 AM. |
