"Cannot Proceed" - Solved - Page 2 at DVinfo.net
Old February 22nd, 2008, 01:13 PM   #16
Same here... playing with the cam and suddenly "Cannot proceed". Thanx for the solution :)
Stupid message, there is enough room for: "Disabled when Direct menu = All" or someting like that.
Michel Satoer is offline   Reply With Quote
Old February 22nd, 2008, 04:34 PM   #17
Phil: Now this is solved can I wander a little and ask you if your are still using CINE4 for what you take into Magic Bullet or do you have more profiles working for you now?
Mike
Michael H. Stevens is offline   Reply With Quote
Old February 22nd, 2008, 06:47 PM   #18
Originally Posted by Carroll Lam View Post
When I finally got down to "Direct Menu" and changed it from "Part" to "All" I started getting the "cannot proceed" warning when I operated either the shutter or gain switches. So, out came the manual and sure 'nuff there at the upper right of page 19 were the words "When the Direct mode is set to "All," tje GAIN, SHUTTER, and WHITE BAL switches are disabled."
Now, I'm a great believer in RTFM and I had studied the manual quite closely and I'd studied the manual for days before receiving my EX1 and I missed that statement completely.
Carroll Lam
Well Carroll, Unlike you, I have no patience so I called Sony tech support after about 2 minutes of trying to figure WTF was wrong! They put me on hold for about 5 minutes while they sorted things out and came back with the exact solution that you arrived at. YUP that was the problem. And yes, now I am reading the manual more as well. I am however impressed at your tenacity!
Best, Craig
Craig Hollenback is offline   Reply
