SD mode- Is it m2t or mxf? at DVinfo.net
Old December 1st, 2007, 10:48 AM   #1
Just wanted to ask if SD needs to be converted from mp4 as well? If yes would it be in m2t format or mxf?
Old December 1st, 2007, 11:27 AM   #2
That depends on what you want to do with the file and what formats the software your moving the clip to accepts. The camera produces MP4-files and the Sony utility converts to MXF. I guess you could transcode into any other formats using the right utility.
Ola Christoffersson is offline   Reply With Quote
Old December 1st, 2007, 06:50 PM   #3
If you connect to a Firestore FS4 with the HDV upgrade you can record standard M2T files on that with the EX1 in SP mode and the firewire output activated.
Old December 1st, 2007, 09:49 PM   #4
SD what? There is no SD recording on the EX1. There is a format selection called SP as in SP 1080i60 or SP 1080i50 and some other.
Those above are 1440x1080 and interlaced. There is no SD formats like PAL 720x576 at all if thats what you ask.
All files are in .mp4 and the Clip Browser only exports to .mxf.
Andreas Johansson is offline   Reply With Quote
Old December 1st, 2007, 10:35 PM   #5
Oops I was refering to 1440x1080 SP 50i. Thks for the inputs. I think it would be possible to mix mxf and m2t on a single timeline with FCP or Vegas Pro..
Old December 2nd, 2007, 01:17 AM   #6
Do you guys know if VideoStudio11+ can support the formats EX1 is outputting?
I read here that the Sony Clip Browser exports to .mxf files. Well are these .mxf files supported by Ulead VideoStudio11+ ?
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old December 2nd, 2007, 09:15 AM   #7
Don't know about Video Studio, but why not download the test clips and give it a try?
Old December 2nd, 2007, 01:12 PM   #8
Andreas
From where can I download the clips?
Stelios
Old December 2nd, 2007, 01:21 PM   #9
I have som clips at ex.bolanski.com
Old December 2nd, 2007, 01:30 PM   #10
Andreas
Can you pin point please which one is the clip to download to try with VideoStudio11+
Stelios
Old December 2nd, 2007, 02:45 PM   #11
Originally Posted by Stelios Christofides View Post
Andreas
Stelios
No, it depends on what you want to test. I have a zip file with almost all formats in it called BPAV.zip under the headline Test shots for ffmpeg those are only 9-12 frames long but for testing NLE's
Old December 2nd, 2007, 05:27 PM   #12
Thanks Andreas
I will try and see which one works.
Stelios
Old December 2nd, 2007, 05:39 PM   #13
NewTek's SpeedEdit editor will also read the native EX files. I've imported all the NTSC formats and they all read fine, even on the same TL together! The only down side is having to go into each clips folder to get to the file, a real pain with many clips!
Brian Jansen is offline   Reply
