¼ 20" screw at DVinfo.net
Old March 2nd, 2008, 10:26 AM   #1
Images: 12
¼ 20" screw
Someone at Zacuto had mentioned a ¼ 20" screw insert on the top of the EX1 which could be used in combination with http://store.zacuto.com/product.php?...1&cat=0&page=2 for monitor mounting. Am I missing it?
Randy Strome is offline   Reply With Quote
Old March 2nd, 2008, 11:57 AM   #2
Check the hot shoe mount
Jim Montgomery is offline   Reply With Quote
Old March 2nd, 2008, 12:15 PM   #3
Images: 12
Thanks Jim,
Are you saying use the hot shoe as an alternative to a threaded insert?
Old March 2nd, 2008, 12:35 PM   #4
Well I just went and checked and there is no hole, my mistake. Best better check with Zacuto.
Sorry
Jim
Old March 2nd, 2008, 09:31 PM   #5
This is my first post on this board. (kind of a test), but I'm gonna go ahead and guess... The shotgun mike mounting bracket screw?
Michael Canion is offline   Reply With Quote
Old March 3rd, 2008, 12:42 AM   #6
Nope, 2x M3 screws. Definately will not hold a monitor.
Has anyone tried levering the silver leaf spring thing out of the cold shoe?
There might be a tapped hole under there.
I doubt it though and I think Zacuto are getting confused with the Z1 where you can remove the cold shoe and use the threaded hole to mount a variety of arms via the 1/4" 20tpi hole.
Old March 3rd, 2008, 01:18 AM   #7
Maybe they're thinking of the HVX which has a conspicuous one right on top of the handle?
Eric Pascarelli is offline   Reply With Quote
Old March 3rd, 2008, 07:58 AM   #8
Images: 12
I believe you are correct. I did not want to get out a jewelers screwdriver and start fiddling around without knowing for sure first.
They do make a hot shoe mount , but I am unsure as to how much weight the hot shoe is really meant to support. Any thoughts?
Old March 3rd, 2008, 08:03 AM   #9
Guys, get real! Even if there WAS a hole under the hot shoe, do you really believe it'd be a good place to fix your monitor to? I mean, even my Sony LED lamp (mush smaller and lighter than any serious monitor) causes the whole mic housing to flex and bend with any serious movement...And remember, it's also the LCD compartment!
Old March 3rd, 2008, 08:32 AM   #10
Images: 12
Good info Pioitr. No, never mounted anything up there...sounds like I never will.
