White Balance and Black Level Adjustments at DVinfo.net
Old April 3rd, 2008, 06:48 PM   #1
I was talking to a friend that is in televison and he was telling me each time they set up a white balance that thier cameras have a switch for the black levels also.
Is it fesable on the ex1 to adjust the black levels on each shoot, if so by how much?
Dustin Gray is offline   Reply With Quote
Old April 4th, 2008, 06:13 AM   #2
This may be a good place to start
HOW TO: Manually White/Black Balance with a Vectorscope by Art Adams on PVC.
The title actually mentions the use of a Paintbox, but you use the camera matrix controls for that (Picture Profiles).
George/
Last edited by George Kroonder; April 4th, 2008 at 08:26 AM. Reason: Oops... wrong credit! Corrected.
George Kroonder is offline   Reply With Quote
Old April 4th, 2008, 07:01 AM   #3
The black balance is not something that is carried out every day as a general rule. Presumably the PP settings will ensure correct black balance on the EX1 depending on the one selected.
Bruce Rawlings is offline   Reply With Quote
Old April 4th, 2008, 07:12 AM   #4
Images: 10
yes, the BLACK level can be adjusted in PP. Whether it's wise to do so, without a waveform monitor, is another matter, entirely.
Old April 4th, 2008, 02:35 PM   #5
Black level, the point considered true black does not directly relate to white balancing which is a color adjustment to take account of the temperature of the light. The black level on the EX1 (not the black gamma) needs be set for every changed lighting condition while white balance may stay the same.
Having now put the EX1 to good use I can tell you it is absolutely necessary to set the black point for every shot for the best results. The histogram works fine for this. Read up on what Randy has written on how to do this with the histogram. It was Randy who put me onto this and it is the best piece of advice I have been given here.
Michael H. Stevens is offline   Reply With Quote
Old April 4th, 2008, 05:09 PM   #6
Randy Link
Could you please give the link for the Randy article?
Paul Burgess is offline   Reply With Quote
Old April 6th, 2008, 12:01 AM   #7
Hi thanks for the info everyone, can someone direct me to Randys info on the histogram, thanks.
Old April 6th, 2008, 05:23 AM   #8
Black Balance is different to Black Point. Black Balance is where the black or dark output level of the 3 sensors (CCD's or CMOS) is matched by adjusting the pre-amp gain or off-set. The Black Point is an adjustment that takes the combined output of the 3 sensors and allows an offset to be applied that raises or lowers the combined dark signal level.
Alister Chapman is offline   Reply
