EX1's LCD flicker? at DVinfo.net
Old April 14th, 2008, 07:57 AM   #1
EX1's LCD flicker?
Sorry for creating a new thread; (might be due to my being p***d off by the EX3's VF revelations), but anyway:
So far, in the Northern hemisphere, we've been using out EX1's in low Sun. Now, with all the glory of spring, I've noticed that when used in bright sunshine, my LCD flickers heavily... Tried it with various settings (recording modes and shutter speeds) - no matter what, it flickers.
Just as if I watched my 100 Hz refresh rate capable plasma, in the 50 Hz mode.
Anyone noticed this?
Last edited by Piotr Wozniacki; April 14th, 2008 at 09:16 AM. Reason: typos; grammar (ashamed of my English...)
Old April 14th, 2008, 08:14 AM   #2
No - I have not. LCD is beautiful.
Eric Pascarelli is offline   Reply With Quote
Old April 14th, 2008, 08:40 AM   #3
Not at all. What recording mode are you in?
Sean Donnelly is offline   Reply With Quote
Old April 14th, 2008, 09:07 AM   #4
As I said - whatever mode.
However, I have now my Letus Extreme attached. I tried to turn the spinning GG on and off; no difference (I thought perhaps some interference was showing off).
I'll report later when I detach the Letus.
Old April 14th, 2008, 09:13 AM   #5
I sent my camera in to Sony service, but I recall seeing the flickering while viewing the LCD outside in good old Arizona sunlight.
Old April 14th, 2008, 09:17 AM   #6
That's my point; in shade (or indoors), I can't see the flicker.
Old April 14th, 2008, 09:24 AM   #7
Yes, mine is too. Noticed it for the first time earlier today.
Geoff
Geoff Addis is offline   Reply With Quote
Old April 14th, 2008, 01:22 PM   #8
Mine does it as well in bright sunlight.
I will install a hoodman - this should solve the problem.
Have you tried switching of the backlight when the flicker appears? I haven´t, but will try that next time it appears.
Gerald Loidl is offline   Reply With Quote
Old April 14th, 2008, 07:59 PM   #9
Images: 3
Turning off the back light makes no difference. I don't see the flickering as a problem.
Serena Steuart is offline   Reply
