Prompt/autocue software and hardware for EX1 at DVinfo.net
Old May 18th, 2008, 04:26 PM   #1
Can anyone recommend prompt autocue software and hardware for the PMW-EX1, but ideally something that will also work with the Reflecmedua "Green screen" system (whicn involves a ring of green lights fitting via a screw adapter to the EX1 lens).
I've heard there may be a system available which can be mounted just above the lens so that the eyeline isn't too far out of wack with what the camera's recording.
Ian Smith is offline   Reply With Quote
Old May 19th, 2008, 05:59 AM   #2
There are some simple "systems" that you can hang below or to the side of the lens, but it will be obvious th etalent is not looking into the lens.
I have no experience with the Reflecmedia lightring, but I see no problem mounting it on top of the prompter instead of on the lens.
George/
Edit: Reflecmedia offers a prompting solution that is basically a widescreen lcd mounted on top of the lens: http://www.reflecmedia.com/education...ting/index.htm
Last edited by George Kroonder; May 19th, 2008 at 06:11 AM. Reason: Added the link
George Kroonder is offline   Reply With Quote
Old May 19th, 2008, 08:46 AM   #3
Hi Ian
I use two different systems.
When I want to use the Reflecmedia system I
use
http://www.tele-prompt.com/html/contact.html
on a laptopset at the same height as the lens (just to the left or right)
the lap top sits on a Manfrotto projector table which is supported by an old photo tripod. I think this works well
Take a look
www.professionalvideo.tv/webvideo
When not uslng Chroma Key I will be using Pro Prompter (just purchased)
Greg Hawkes is offline   Reply
