-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Microphone Mounts - EX1 vs. EX3 (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/127056-microphone-mounts-ex1-vs-ex3.html)
Ted OMalley July 31st, 2008 06:25 AM
3 Attachment(s)
From everything that I've read on the formums (and there are a lot of posts here, so forgive me if I missed something), it has been indicated that the mic mount design of the EX3 has not changed - that it will have the same weaknesses as the EX1.
Since I have never owned an EX1 and my EX3 is not due until tomorrow, I really wouldn't know. However, I have compared some very similar high-res pictures online and it seems that there has been a significant redesign.
In the cropped images below, the EX3 mic mount seems to be an additional 1/4" thicker at it's base - which is where I presumed the weak spot was. I know the angles are slightly different, but behind the shoe, where the controls are, they seem quite different.
Can any EX3 owners that have owned or do own an EX1 confirm or deny this? I'm thinking that a short shotgun on the EX3 may not require removal and redesign of the mic mount system. Maybe I can just add the Rode SM5 and my NG-1 and that's all. Any thoughts?
Ned Soltz July 31st, 2008 07:13 AM
I'm sitting in front of both EX-1 and EX-3 right now and don't see a bit of difference.
Dave Morrison July 31st, 2008 08:07 AM
From those photos, it appears that the EX3's base simply sits slightly higher than the one on the EX1 (or vice versa) thereby making the base look thicker, no?
Ted OMalley July 31st, 2008 08:13 AM
I've been viewing some additional photos and I think I'm coming to that conclusion. Probably the controls sit lower on the EX3 because the the LCD doesn't have to fit underneath it.
Ned Soltz July 31st, 2008 08:18 AM
I really do not see any difference... and both cameras are right in front of me.
The one difference with the EX-3, however, is that the end of the lens hood is about another inch beyond the end of the built in mike-- meaning it will be easier to mount matteboxes.
Ray Bell July 31st, 2008 02:11 PM
Are these mounted the same way they mount on the PD-170 ??? ( two screws )
