Thoughts on white balance and minimizing noise levels. at DVinfo.net
Old December 31st, 2008, 12:00 PM   #1
In the past there's been some discussion on using warm cards (blue cards) to create an inbox look. There's obvious pros and cons. Some feel the image should be taken as color balanced as possible and all color looks should be done in post.
With white balancing under tungsten lighting (2800K-3200K), the blue channel tends to be the noisest. I can see why it may be an advantage to use warm cards. The real question is - if you decide in post to bring back up the blue channel for a balanced white, will that negate the blue channel noise improvement?
I guess some experiments would need to be performed.
Old December 31st, 2008, 12:32 PM   #2
Yes. In fact, it would be slightly worse than bringing up the blue channel in production. This is due to the same reasons that it's better to use gain in an 8-bit video camera than do gain in post: quantization, nonlinear signal processing, and compression.
Daniel Browning is offline   Reply With Quote
Old December 31st, 2008, 02:42 PM   #3
Thanks Dan, good point.
Steven Thomas is offline   Reply
