Chrosziel Mattebox for EX 1 at DVinfo.net
Old February 8th, 2009, 09:41 AM   #1
Does anyone have experience with the Chrosziel mattebox marketed for the EX -1. Here's a description and picture:
Chrosziel 450-EX1K2 Mattebox / Follow Focus Kit for Sony PMW-EX1 :: Matteboxes & Sunshades :: Equipment Sales :: Abel Cine Tech
I'm only interested in the mattebox, not the follow focus, which I think sells for about $1800 with rails. I will not be using this with a 35mm adapter (for now) just the stock camera.
Does it fit properly on the EX-1? I've heard that a lot of matte boxes don't fit properly, either because they crowd the mic or don't permit the LCD to swing out. The linked picture doesn't give a good idea of how close it's sitting to the LCD.
I'm considering this and the Redrock but haven't been able to answer the question about the micro matte box either.
And while I'm at it, are two filter stages enough? I can only imagine using two at a time but I'm open to hearing about others' experiences.
Bob Kerner is offline   Reply With Quote
Old February 8th, 2009, 09:52 AM   #2
Sponsor: Abel CineTech
Hey Bob
The Chrosziel fits the camera nicely and the LCD does open when it is on. The only problem is that you cannot rotate the second stage without hitting the LCD.
Check out the Arri Mattebox as well: Arri MMB-1 Basic Mattebox Kit :: Mattebox Systems :: Matteboxes & Sunshades :: Equipment Sales :: Abel Cine Tech
It was designed to work specifically with the EX1 camera and the second stage clears the LCD.
They are both great systems and fit snuggly. I'd like to hear what people think about only having two stages, but it seems to be the only option in this size mattebox.
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old February 8th, 2009, 09:59 AM   #3
Thanks Andy. I didn't see that one, just a much more expensive version. Brian from RR responded to me in another forum that the MM works with a rubber gasket to get it a little further away from the lens.
Do you use this? What do you make of the fact that it is side loading, not top loading?
Edit: Now I recall seeing this and thinking it wasn't quite right. Read Doug Jensen's post #20 on this thread:
http://www.dvinfo.net/conf/sony-xdca...my-cart-2.html
He has a good point (that I forgot to bring out in my original question) about side loading being a hinderance if trying to position grad ND filters.
I can't tell whether the Chrosziel is top or side loading from the description......
Old February 8th, 2009, 10:25 AM   #4
I think the Arri is $1500 about $300 less then the Chrosziel. I'm sure the RR is less though but I haven't played with that one yet. I know a lot of people are happy with them.
The Arri has that issue with ND grads for sure.. it was a decision that came about because of the space available on the EX1. The Chrosziel is top loading but has the rotation issue.
Old February 8th, 2009, 04:24 PM   #5
That is the old model 450. There are two new Chrosziel base models out, the CMB-R10 and 20, and the 450R1, 2 and 3. They have 1 to 3 360 rotating trays, not a single 360. CMB being the light weight version, clampable or rods.
I haven't seen one in real life, but you'd think they'd design them to work properly with the EX1/3. My mouse is hovering over the Buy button for a CMB-R20 for my EX3.
David C. Williams is offline   Reply With Quote
Old February 8th, 2009, 04:49 PM   #6
Originally Posted by Andy Shipsides View Post
The Chrosziel fits the camera nicely and the LCD does open when it is on. The only problem is that you cannot rotate the second stage without hitting the LCD. Check out the Arri Mattebox as well... I'd like to hear what people think about only having two stages.
I am in the process of getting a new mattebox however I have the EX3. The one issue, although temporary, is the ARRI does not have a shipping eyebrow or sideflags which defeats a large part of why someone would drop a lot of money for a mattebox. I phoned Eric Johnson at ARRI and spoke with him about the issue and in general terms about the mattebox (and follow focus). The eyebrow and side flags are in manufacturing and are supposed to be shipping in a month's time. You can use the eyebrow from its bigger brethren but it dwarfs the mattebox but still very usuable. The backend of the ARRI is suppose to match up nicely to the EX1 and EX3 but I would like verification of that from a seasoned user. Eric mentioned that the ARRI, like most matteboxes will vignette when you use the wide angle adapters that are available, however, I am pretty sure you can rig up something where you push the lens through the opening a bit but you would probably loose the use of the filters.
The nice thing about the Chroszeil is they have a raft of adapters for pretty much any lens diameter, the build quality is excellent and it is a known commodity with a track record. They are pricey but in the same league as the ARRI (depending on where you buy it).
The issue of the rotating stage on the Chroszeil is not lost on me and that is why the ARRI is very much a consideration but I am going to wait until the flags are available and some pros get their mitts on them and speak up.
EDIT:
One more thing the ARRI pricing the Abel Cine Tech is giving (which is good) does NOT include the eyebrow. I believe Mr Johnson from ARRI said the suggested price on the brow was around $150 and the sideflags were in the $250 range.
To me when you are in the that price range and the fact that a mattebox should last you several cameras (hopefully more) the price spread is moot.
Old February 8th, 2009, 06:59 PM   #7
Do you have a link for this, David?
This is what's on the manufacturer's website and it looks the same as the Abel link:
Chrosziel GmbH - For DVD and HDTV Camcorders
I don't see a 450 R 1 listed on their product list.
Does anyone have experience with the Petroff matee box sold by Zacuto?
Old February 8th, 2009, 07:33 PM   #8
Chrosziel finally has a website. Lots of product information. Really helps out as the vendors for their stuff generally having outdated product listings. Check it out here...
Chrosziel GmbH
Old February 8th, 2009, 08:25 PM   #9
The 450R series is new, and may not be in retail yet. the CMB-R20 has been out for awhile though. Even the Chrosziel website barely has 450R info. If you look in their full catalogue PDF, it's there.
http://www.chrosziel.com/data/chrosz..._Catalogue.pdf
The CMB-R20 is on B&H
Chrosziel | AC-CMB-R20-EX1K1 Sunshade Kit 1 | R20-EX1-K1 | B&H
Old February 9th, 2009, 01:18 AM   #10
Images: 3
I'm using the Chroziel that I bought for the Z1 - just had to modify the transition piece and file out the front mask (which is a "plastic" clip in). The usual thing for the Z1 and EX is to load filters from the bottom, and I find free rotation of the stage (of course if the carrier is pulled out it will hit the built-in mike).
Old February 9th, 2009, 10:11 AM   #11
I know I'm splitting hairs, but why is this product listed as a Sun shade rather than a matte box? This implies there is a difference.
Old February 9th, 2009, 11:21 AM   #12
You aren't splitting hairs. If you want a rails version you should go for other one. You will also note the eyebrow (french flag) on the rails version is split, you will of course have the rails mount. I haven't seen the price on their swing away unit. The Zacuto one has the flexibility of being usable on any mattebox with a rail adapter on it & it pulls straight out a bit and then swings. Not sure if the Chrosziel does that.
Old February 19th, 2009, 01:59 PM   #13
Is this the new one you are referring to?:
Looks like it fits. What I cannot determine from the description is whether it will accept side wings, or is that the feature that distinguishes it from being a matte box (it's marketed as a sunshade)?
Old February 19th, 2009, 03:25 PM   #14
That's the one. I'm not sure why they name a sunshade? Perhaps you can't buy hard mattes for it? There is probably some obscure definition the Germanic need for order can't avoid. All the pictures I've seen show side wing mounts, but I haven't seen a live one.
I ordered and paid for it 2 weeks ago from B&H, but it hasn't even shipped yet :(
www.davidwilliams.com.au
Old February 19th, 2009, 07:52 PM   #15
Images: 3
The Chrosziel link is : Chrosziel GmbH - For DVD and HDTV Camcorders. The product code is 450-EX1KIT. That takes mattes. But that is listed under both matte and sunshade, so I've added nothing to the previous posts. The matte-box I use is the 450-HDVKIT (see my contribution further up) which is the same in major details. Good kit.
Serena Steuart is offline   Reply
