PMW - EX30 Timecode at DVinfo.net
Old February 24th, 2009, 04:01 AM   #1
PMW - EX30 Timecode
I am planning to transfer some HDCAM footage to SXS for a location edit. Does anyone know if the EX30 recording deck will see original time code on the incoming HD-SDI pictures?
Bruce Rawlings is offline   Reply With Quote
Old February 24th, 2009, 03:08 PM   #2
Yes, just change the TC menu to 'EXT Regen'. You will still have to manually trigger record though on the EX-30.
Another handy tip for EX-30 field work: Snip the AC Adapter cable between the yellow DC Jack and the AC Adapter itself and add a 4pin XLR Male Connector. On the AC Adapter end add a female 4pin XLR Connector.
You can now field power the EX-30 off any 12 volt source with a 4pin XLR connector. The unit only draws 12W.
Simply plug the 2 4pin XLR's together when you want to go back to mains.
Scott Webster is offline   Reply With Quote
Old February 24th, 2009, 11:19 PM   #3
Thanks Scott, Your information is greatly appreciated.
