EX1 shutter speed at DVinfo.net
Old March 11th, 2009, 12:33 AM   #1
EX1 shutter speed
Hello
although I set the shutter speed in the menu to 1/60 , but in the LCD menu the SHT shows as off !!
Any help .
Laffan Nasser is offline   Reply With Quote
Old March 11th, 2009, 12:52 AM   #2
Reach around the front of the camera and turn the shutter on.
Problem solved.
Old March 11th, 2009, 02:36 AM   #3
Problem solved.
Grate
Thanks Perrone
Old March 11th, 2009, 03:14 AM   #4
I don't have an EX1 but using a friends a few days ago I was trying to access the very slow shutter speeds. On my Z1 I simply scroll the wheel and it goes 1/50th, 1/25th, 12, 6, 3. What does the EX1 show when it goes down to these vely long shutter speeds?
Old March 11th, 2009, 04:16 AM   #5
Images: 3
It has a frame accumulation mode entered via the menu.
Old March 11th, 2009, 04:24 AM   #6
And could you tell me what FAM does and what settings are what?
Old March 11th, 2009, 04:55 AM   #7
Frame accumulation appears to use a frame store and add the last x captured frames to create the frame it records. x can be 2-8 using SLS or 16, 32 or 64 using EX Slow Shutter. Apart from giving a ghostly effect to any movement, adding the frames boosts light sensitivity.
Nick Wilson is offline   Reply
