Settings in UK - Page 2 at DVinfo.net
Old August 4th, 2009, 03:44 AM   #16
Originally Posted by Dave Tyrer View Post
As that won't really affect me I'll run some tests when I get all my kit together. It looks like I can convert in Vegas Pro.
One thing I hadn't considered when converting from 30P to 25P would be the change in audio. Looks like it will have to be 25P after all.
Just out of interest is there any way to preserve the original audio when down converting from 30P to 25P or 24P?
If this sounds like a total newbie question it's because I am...so please don't get too technical.
Dave Tyrer is offline   Reply With Quote
Old August 4th, 2009, 04:03 AM   #17
The audio should stay the same, i.e. if you have recorded 1 min of footahe then the audio will play for 1 min, regardless if you have shot at 25, 24 or 60 fps etc. A fail safe method would be to save the audio as a seperate file, most good audio applications will let you import the soundtrack from any video clip.
Old August 4th, 2009, 04:59 AM   #18
So are you saying the audio doesn't slow down or speed up depending on what you convert to?
Old August 4th, 2009, 05:11 AM   #19
No, the audio will stay the same. If you shoot 24 fps or 30 fps the total will still be one second of footage. Audio works with time, not frames per second. Think of a pie, if you devide the pie with four people you will have four sections, devide it with eight people and you will have eight sections, but the total will still be one pie. I am feeling hungry now, it must be lunch time.
Old August 4th, 2009, 06:32 AM   #20
Lol...enjoy your lunch. Great explanation...thanks Vincent. No reason why I shouldn't shoot in 30P then :-)
Old August 4th, 2009, 08:37 AM   #21
That was your original question Dave and I waited for a positive confirmation on that as a fellow PAL lander. I find I am struggling a bit with 25P shutter speed 50 any time I pan, even slowly. I would prefer 30P. Is this a definitive yes from the group that 30P 50 is a usable combo?
David Herman is offline   Reply With Quote
Old August 4th, 2009, 09:37 AM   #22
David I think the shutter speed for 30P should be 1/60 - 1/50 would be for 25P and 1/48 for 24P
