When Switching Live , then stuffing that into a computer:
When smooth (slow or fast) DISSOLVES between 2 cameras does not MATCH exactally in color, and there are 300+ of them in hour, that Post Processing the now combined video in normal computer editors would take Twice as long as it would take to re-edit the whole thing in the computer from the original cameras backup recordings. that means either it is matching before i start, and 30+ hours of editing are done Live in 1 hour, or i might as well have shot it FOR wasting 30 hours editing it. Post color correcting 1of2 cameras that are mix together already , and not with cuts, means not only color correcting little pieces at a time but also having to Keyframe the color changes through the dissolve AT the dissolve rate which varies. meaning no computer could use its magic, unless it was AUTO color, and we all know it would fail miserably as the pictures change. Cam A +++ Cam B --- Both ==== ++++++++=======---------========++++++++=======---------======== |color A | Keyframe| color B | Keyframe|color A | Keyframe| color B | Keyframe| Post Color processing the FINAL mix, when both cameras Match, means post processing both at the same time, which is easy, and Whole sections of the combined can even have different post processing. so there is No post processing Both cameras as seperate units once dissolved/mixed, unless you just want to torture yourself :-) |
"Just like we did it in the olden days". I've shot a lot of two cam stuff with Z1s and I've mucked in on a couple of the MacVideo multicam shoots (the Adobe event and slightly less so, the FCP SuperMeet in London) and though I say so myself, the two EX1s were pretty damn close - I used the same picture profiles then did a symultaneous white set with the card in the presenter's light and the cameras brought to it (not white set in position). What I can say: two EX1s with identical Picture Profiles, and identical Preset White Balances, DO NOT MATCH. There's production differences, quantum level events, moments at the factory where the food was bad in the canteen, whatever. The two did not match. The way to make them match was to do a manual, but simultaneous white set. Just like I learned from the engineers in the studio 20 (eek, 25) years ago - gather your cameras together in a little huddle, point them at a single source in the position of your main (mean, modal, average) presenter position, and line them all up from that. For the engineers, that was a manual black balance, white balance, gamma, pedestal, iris and so on. I guess we just get the same Picture Profile, then White Set at the same iris, gain and and shutter speed. But hold on one cotton picking second - I am trying to analyse what you're really wanting to do and what I haven't seen in your explanation is the use of 'multicam' editing. I use Final Cut Pro, but I think other edit systems do this: You film each camera angle as one long take per camera, and sync then up with each other in your edit system. You then play back each stream symultaneously and in sync, with a preview of each camera, then using the keyboard, effectively vision mix the whole enseble together. Any screw-ups, and you simply stop, back up a bit, then go again. Any additional stuff you do, you do. At the end, you export your vision mixed, colour corrected, captioned edit as one movie. The trick is that you only need colour-correct each camera ONCE. Do the heavy lifting with a mutual white set, then go the last mile in post. Then just cut on the fly. Would that float your boat? |
Indeed what you said , but i didnt hear the part about them not matching , brain freeze :-)
initially i will do the seperated cams on seperate timelines , color match the two cams , then blend. $10,000 dollers later (price of switcher), i will be going back to Live shooting with matched cameras. And if they dont match then tell sony i am going to buy CHEAP cameras for the other views , and match them instead :-) mabey Cannons or panasonics even. tell them that for $2000 instead of $6000 i can get by on one leg , see if they quit having them manufactured in china :-) If i gotta get EX-3rs and $2000 doller "paint boxes", i will send the whole kit back, move to cancun and retire on the money i saved :-) WTF do they call them paint boxes for anyways, they dont paint nothing, they should be called CCMU Crappy Color Matching Units |
"What I can say: two EX1s with identical Picture Profiles, and identical Preset White Balances, DO NOT MATCH. There's production differences, quantum level events, moments at the factory where the food was bad in the canteen, whatever. The two did not match."
YUP! Too bad but that's the real world. |
YouTube - Nipros CCU for EX3 Frightening costs. |
| All times are GMT -6. The time now is 04:43 PM. |
