i use a chest stick (rarely), and the support point has to land on the bone right above the diaphram centered, or back down on the waist. anywhere else on the chest just wont cut it.
i dont have a problem with breathing effecting it then, but then again i dont breathe when i shoot :-) the thing i want to know most about the sony shoulder support is whan it is folded up and tossed on a tripod, with IT still attached, does it exisiting there (between them) cause even the smallest of movement between the tripod head and camera, when panning or tilting. That is the first thing that came to mind when i saw that design. If there is even a micro bump when changing from panning left to panning right with a hard drag setting on the tripod, because of the thing between the head and the camera, it would be irritating when following, like say your trying to follow a Ice Skater in circles, and at each return a tiny bump hits. |
I really like the design of your brace - but I'm wondering how it breaks down to put the camera in a bag or case ( I use a Kata CCC-10-A). Is there a quick release or would I have to unscrew it from the camera's tripod mount every time? |
Hi Ronn,
It doesn't break down, so you'll usually have to dismount the camera to pack up. However, it does allow you to mount a tripod quick-release plate on the shoulder mount so yo can go back and forth from tripod to hand-held. |
| All times are GMT -6. The time now is 01:51 AM. |
