-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX3 Genlock Questions (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/477605-ex3-genlock-questions.html)
Steve Kalle April 26th, 2010 01:21 AM
2 Questions:
1) How do I use the EX3's genlock with an EX1?
2) As I understand, genlock can be used to start each camera's recording at identical times. So, do both cameras need to stay connected after recording begins? (they would both be recording 3+hrs continuous)
Rick Jones April 26th, 2010 09:34 AM
EX1 can't be GenLocked because it doesn't support it. EX3 or 350 only.
Marc Myers April 26th, 2010 10:45 AM
That said, if you are switching live your switcher may well have frame synchronization for one or more inputs. I regularly switch among four EX1s using a Panasonic AV-HS300. Works great. Genlock was one of those things I didn't mind giving up when we stopped analog production.
Alister Chapman April 26th, 2010 11:12 AM
Genlock allows two cameras to be synced together so that each frame being recorded starts at the exact same time. This is essential if you want to use the cameras to feed a vision mixer that doesn't have timebase correction on it's inputs. It is also useful for 3D and other applications where the cameras must be synchronised to each other.
Genlock does not control when the cameras go in to record, nor does it lock the timecodes together. To lock timecode you need to feed timecode from camera to camera. To make both cameras start recording together you would need a remote control device that triggers both cameras.
You can genlock an EX1 to and EX3. The EX1 would act as the master camera and you take the Y signal from the component output of the EX1 and feed that to the Genlock input of the EX3, the EX3 will then adjust it's timebase to match that of the EX1. You need the cameras to remain connected for them to stay in Sync.
Steve Kalle April 26th, 2010 11:28 AM
Thanks Allister. Its funny because I was just on your site trying to find where you posted about doing this with your EX1 & EX3 for 3D work. That is where I got the idea, although I won't be shooting 3D.
