Ex 3 red residue in lens at DVinfo.net
Old July 6th, 2010, 04:03 PM   #1
I an very meticulous when cleaning my Ex-3 after every shoot. I operate in a dusty environment shooting dirt racing video. When cleaning my camera just now I looked into the lens while cleaning the uv filter and noticed a red substance right around the iris of the lens. It almost looks like it belongs there and is just around the iris like a narrow ring. It occurred to me that it is the same color of some of the race track dust I shoot in. I keep a UV filter on all the time and always keep the lens cap closed when not shooting.
Any one noticed a similar ring or circle around the iris on your EX stock lens? If so how can it be removed?
So far I cannot tell any effects on my footage. The camera has just over 100 hours and at the end of this season will go back to Sony for cleaning and firmware updates. I wonder if the Sony service center in NJ has the ability to clean inside the lens?
Thanks guys.. loving my Ex-3
Ronnie
www.ramtv.tv
Ronnie Martin
Kato Video
Ronnie Martin is offline   Reply With Quote
Old July 8th, 2010, 04:56 PM   #2
since I do not have a way to compare what I am seeing in my camera, would someone be so kind as to look into their lens and see it there is a slightly red ring around the iris of the stock Ex-3 lens?
Ronnie
Ronnie Martin
Kato Video
Old July 8th, 2010, 05:58 PM   #3
I don't see any on mine.
Charles Newcomb is offline   Reply With Quote
Old July 8th, 2010, 06:27 PM   #4
Thanks Charles... I checked with Sony Service in NJ and they said that they could handle the cleaning of the lens in house without sending it off to the lens company.... So far I have not seen any problem with my footage. I am just worried about that being in the lens. It is just a thin circular redish ring about 2mm wide around the iris of the lens.
Ronnie
[url=http://www.ramtv.tv]
[url=http://www.dirtracingvideo.com]
Ronnie Martin
Kato Video
Old July 14th, 2010, 01:05 PM   #5
One more question... how can I prevent this from happening again? I assume the dust is getting in from the front of the lens... Or could it be the gap where the lens fits to the camera body? Would some good old gaffers tape around the gap at the lens and body connection help? Any ideas of how to prevent dust getting into the camera in dusty conditions?
Ronnie
www.ramtv.tv
Ronnie Martin
Kato Video
Old July 15th, 2010, 12:31 AM   #6
My EX3 was covered in red dust on my recent trip to Africa, I used a heavy duty blower (Giotto) and a small soft, but stiff, paintbrush to remove dust at the end of each day. Have just taken a close look at the iris blades and there is no dust/red ring on it.
Get a good magnifying glass and make sure it is not rust, otherwise just carry on shooting.
Old July 15th, 2010, 07:02 AM   #7
Thanks Vincent for your advice. I use a swifter dust cloth during and directly after the shoot trying to catch the dust before it has time to seep into the camera. Then when I am back to where there is AC power I use a vacuum cleaner with a small tip to go aver the cracks and crevices where dust has collected. It has one tool with a small brush and others with a small tips. I am still not sure what I am seeing down in the lens. It could just be paranoia on my part. I have had such good results with the EX-3 and the EX-1 that I really am over protective with my cameras. So far I have not noticed any problem with the footage that I am acquiring except for being way behind on editing it. I am 12 shows into a 20 show commitment and fading fast. When this gig is over I plan to send all the cameras back to Sony in NJ for cleaning and firmware updates.
Thanks again
Ronnie
www.ramtv.tv
Page 1
Ronnie Martin
Kato Video
Old July 15th, 2010, 07:15 AM   #8
Ronnie,
I can understand your concerns regarding the red dust on the iris blades, however, if you can't see any problems on the footage then just carry on shooting. I used to keep cameras and lenses spotless too, not a fingerprint or scratch in sight, the only trouble was that I wasn't using my gear as much as I should be. I was too concerned that it would get damaged.
Although today I still look after my equipment, I have become less fussy about keeping it in mint condition, I just enjoy using the gear.
If you want to see what happened to my EX3 after owning it for two months, then take a look here
http://www.dvinfo.net/forum/sony-xdc...3-useless.html
Have a look at the picture in Post Number 7 or click on the link below
ex3
Don't let a spot or two of dust spoil your enjoyment :-)
Vincent Oliver is offline   Reply
