Offloading clips to MacBook at DVinfo.net
Old August 11th, 2010, 11:12 AM   #1
Hi there,
I know there are other ways of emptying cards whilst on a shoot but all I have (in the meantime) at my disposal is a MacBook. After a shoot I'd then ingest the footage from the Macbook into my Mac Pro, and any other footage from the cards, then edit.
Do I have to install Final Cut on said laptop or can I just install Log and Transfer or Sony Xdcam Transfer? From memory I thought both were Final Cut plugins. I do not wish to edit on the laptop, just use it to offload clips. Plus, the MacBook is my girlfriends and she does not want Final Cut permanently on her Mac, silly girl ha ha!!
Any help much appreciated!
Darren Ruddock is offline   Reply With Quote
Old August 11th, 2010, 11:53 AM   #2
Images: 10
Personally I just copy the BPAVs to the hard drive and use 'compare' in Toast to check the is the same.
Or you can use one of the Sony programs to copy the files, but I don't know about that.
Old August 11th, 2010, 12:24 PM   #3
I wish the MacBooks had the SD card slot. You'd be able to shoot with the SDHC adaptor, add ClipBrowser to the computer and you'd be able to import as well as screen clips
If you're just using for import all you'd need is ClipBrowser and a means to import the cards. As noted, ClipBrowser will copy and do CRC check (why take the extra step of using Toast although it can certainly check too) and you'd be able to screen clips as well.
Old August 11th, 2010, 12:26 PM   #4
Hi,
So in theory I could just grab plug the camera into the MacBook, grab the files off and when I put them onto the Mac Pro later all should be ok??
Old August 11th, 2010, 12:28 PM   #5
Originally Posted by Darren Ruddock View Post
Hi,
If all you do is "grab" and not do CRC check (or even in Toast as Duncan suggests) you may not be OK. If there's a bad copy and you erase your cards, your corrupted shots are gone. BTW this is why I think offloading during a shoot is generally a bad idea. It's opening the door to a fatal mistake. I'd much prefer to have enough cards and given the price of SxS, SDHC adaptor and GOOD quality cards are a viable alternative.
I'd rather spend $800 US on 4 32GB Sandisk Extreme Class 10 for nearly 8 hours of video than risk an offload during a shoot.
Old August 11th, 2010, 12:35 PM   #6
Thanks Craig,
Wonderful.......if you have the funds!!
Old August 11th, 2010, 12:47 PM   #7
Thanks Craig,
For SDHC cards? Make sure you bill enough to afford. They're a major bargain compared to SxS and are getting safer to use as the adaptors and Sony firmware have improved.
Old August 11th, 2010, 12:55 PM   #8
I suppose I have always been wary of them. Always preferred to stick by sxs. Worth investigating.
Old August 11th, 2010, 01:01 PM   #9
Get a NextoDI NVS2500 and you won't have to worry about offloads. Fast, simple, reliable and very easy. Not cheap, but you don't need to have so many cards when you can offload 16Gb in 3 mins.
Alister Chapman is offline   Reply
