HDMI/SDI out on a EX1R at DVinfo.net
Old January 5th, 2011, 01:13 PM   #1
Can both HDMI and SDI out ports work at the same time on my EX1R.
Thank you, Claude
Claude Levet is offline   Reply With Quote
Old January 5th, 2011, 02:32 PM   #2
As far as I know, it is only one or the other.
Ned Soltz is offline   Reply With Quote
Old January 5th, 2011, 09:40 PM   #3
I just tried this last night: a monitor to the HDMI and a Ki-Pro to the SDI. Kept getting a message that the input was changing with flashing lights on the Ki-Pro and got no picture on the monitor, no-go.
esquared
Eric Emerick is offline   Reply With Quote
Old January 6th, 2011, 03:49 AM   #4
thanks to all....
Looks like only one at a time.....Claude
Old January 6th, 2011, 06:34 AM   #5
Sponsor: Westside AV
If you have a NanoFlash you can output SDI to the NF and the NF will then output both SDI and HDMI. And SDI also loops out.
This is nice if you need to feed multiple monitors w/o loop through.
Old January 10th, 2011, 01:39 PM   #6
With the Ki Pro connected to your camera's SDI output, can you not connect the Ki Pro's HDMI output to your monitor, thereby providing a solution for the camera's one-or-the-other limitation?
Ron Wilk is offline   Reply
