Powerlok BP-U60 65WH (BPU60) battery at DVinfo.net
Old August 30th, 2011, 10:51 AM   #1
Anyone use the Powerlok BP-U60 65WH (BPU60) battery from CreativeVideo? How long does it last?
Powerlok BP-U65 65WH (BP-U60) high capacity battery pack for Sony PMW-EX1, EX1R, EX3 and EX3/2 camcorders (14.8V, 4.4Ah, 65Wh)
Mark Slocombe, CreationVideo
http://www.creationvideo.com
Mark Slocombe is offline   Reply With Quote
Old August 30th, 2011, 05:26 PM   #2
Re: Powerlok BP-U60 65WH (BPU60) battery
Same as the BP -U60 that Sony sells. I use a similar battery but different make.
You probably know this but it is worth stating... The battery does not communicate the time remaining like the Sony branded batteries do. You will see the voltage displayed in the EVF in the upper left corner of the EVF. The advantages are price and that you have an Anton Bauer like female P-Tap (D-Tap) connector on the side of the battery. Great for powering accessories.
On an EX1/EX1R/EX3 the battery lasts for hours. Once you start putting on accessories, of course, the length of time the battery lasts goes down.
If you shoot a lot of event video where you need continuous recording in excess of 3 hours you should go to a 90 watt hour battery.
Andrew Stone is offline   Reply
