-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Checking life of SXS cards (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/507799-checking-life-sxs-cards.html)
Robin Probyn May 15th, 2012 03:25 AM
Im sure Ive read somewhere that either in XDCAM browser or in camera.. they was some way to check the life of 1 type SXS cards..?
Jack Zhang May 15th, 2012 07:56 PM
Re: Checking life of SXS cards
In the Status screen of your XDCAM EX based camera, it should show it as both a percentage and a progress bar. I do not believe Browser can see this data, and even if it did, you might have to pay $200 to view it.
Robin Probyn May 16th, 2012 12:12 AM
Ok thanks .. will have the camera soon..
Robin Probyn May 22nd, 2012 01:18 AM
Sorry I didn't mean the time left for recording.But the actual life span of the 1 type cards..maybe the camera just gives some sort of warning when a card is nearing the end of its life span..?
Jack Zhang May 22nd, 2012 05:12 AM
It should be on the final status screen called BATTERY/MEDIA. My mistake though as it only shows it as a percentage as "Life: 99%". The progress bar is how much recording time is left.
Robin Probyn May 22nd, 2012 05:36 AM
It looked to me when I had cards in the camera PMW500 that the % was also referring to the recording time left on the card.. not its cycle life ?
Jack Zhang May 22nd, 2012 10:14 PM
According to the manual, it should be in the BATTERY/MEDIA status screen. To get there, you have to press the MENU CANCEL/PRST/ESCAPE switch to the CANCEL/PRST side. This is below the Gain switches.
Simon Denny May 23rd, 2012 12:52 AM
Jack is correct as far as my knowledge goes. I'm using 5yr life span cards and I have used 2% after one years worth of work or I have 98% life span left on the cards.
Robin Probyn May 23rd, 2012 05:47 AM
Ok thanks to both of you.. getting the camera on the weekend and new cards.. so not something I have to worry about straight away :)
Thanks again
Richard Cavell May 28th, 2012 05:06 AM
Just for the record, I have one 32 gig card (of the SxS-1 variety, not the Pro variety) and so far we've put about 250 gigs of data through it, and it's coming up as 100% life remaining on our EX1R. So at this rate it'll last a very long time. The only marketed difference between the -1 and the Pro is that the Pro is meant to last for more life cycles.
Frankly I don't know why anyone would use the hard disk recorder or any other method of recording data. (Assuming you're not mixing live).
Richard
Jack Zhang May 28th, 2012 05:36 AM
My thought is the HDD units are for long trips with no offloading capability. (for instance, backpacking nature photography trips)
Richard Cavell May 28th, 2012 05:51 AM
Jack, you might be right. But you could also take a netbook with an express card slot and get more functionality. The hard disks don't do slow motion (can't handle the bit rate) and won't let the card door close properly. They only take 120 gig when the SxS cards will already take 64.
A camera with 2 x 64 gig cards installed can record 8 hours of 1080i or 720p footage at highest quality. And you can always just buy more SxS cards. They're only $1200 each... :)
Richard
Robin Probyn June 1st, 2012 04:33 PM
Jack
I bought the camera on the weekend.. and yes you are totally correct .. that status page does seem to show a life of card on %.. thanks..
