EX1 zoom malfunction at DVinfo.net
Old July 28th, 2012, 01:24 PM   #1
Hi All,
One of my EX1's has stopped zooming. Already checked the zoom/servo switch on the bottom of the lens but that's not the issue. It zooms manually with the ring but the electric zoom switches on both the handgrip and the top handle don't work. It wasn't giving problems before and stopped zooming from one moment to the other. Am I missing something or is it really broken? Any help is appreciated.
Gabor
Gabor Heeres is offline   Reply With Quote
Old July 28th, 2012, 07:44 PM   #2
Re: EX1 zoom malfunction
Originally Posted by Gabor Heeres View Post
Hi All,
Gabor
Sounds like the servo zoom has been set to manual.. usually the switch is under the servo motor. or there a bouts.. sorry don't know the camera that well..
Robin Probyn is offline   Reply With Quote
Old July 28th, 2012, 09:38 PM   #3
.....so.....you didn't read what he wrote? ;-)
Old July 29th, 2012, 05:27 AM   #4
Do you hear the motor noise from the gear? If you don't, it's dead. If you do, something has affected the gear to no longer touch the sprockets on the zoom. Unfortunately this would require the entire lens block to be replaced.
Old July 29th, 2012, 07:20 AM   #5
ah yes see what you mean.. but might be some other little switch somewhere.. if it was fine.. and its not making any noise or smoke coming out of the motor.. and neither zoom controls are working.. could be a switch..
I havnt used this camera but those small ones have all sorts of tiny switches they get knocked or pushed very easily..
Old July 29th, 2012, 12:48 PM   #6
Might be worth trying a full reset of the camera.
Old July 31st, 2012, 03:56 AM   #7
Well, it seems our EX1 is living again! As through a miracle the camera started zooming again after by accident holding the Push-AF button for a few seconds (which my colleague normally never uses). To me it seems nearly impossible that AF has something to do with the malfunctioned zoom, but OK, it works! Just wondering now for how long....
Thanks for the help anyway.....
Old July 31st, 2012, 06:09 AM   #8
See.. tiny switches :) might be some weird un announced function to confuse the enemy..
