xdcam transfer
been using clip browser to transfer my footage from sxs in ex1r. told to use xdcam transfer instead. cannot find this anywhere on sony site to download.
had a friend shoot something for me on a pmw200 on sony adapter with sd cards. when I opened clip browser, instead of there being one single clip, it was one long nonstop shoot, it showed 8 clips with x's in them, not like my usual mxf file I see there with ex1r. I had to bring bpav folder to my computer then go into the CLPR folder and there were 8 folders with an mp4file in each one. had to bring them in one at a time and then link them together on my timeline. never have seen the clips with x's through them before. not sure why. |
Re: xdcam transfer
Re: xdcam transfer
The reason is that 35mbps XDCamEX uses FAT32 file structure, unlike the UDF file structure used by 50mbpsXDCamHD. FAT32 allows a max file size of 4GB so the camera is forced to split the non-stop recording up into multiple segments to be stitched together seamlessly by XDCam Transfer or Content Browser.
And frankly for the $20, Sony's Content Browser is a far more elegant tool. |
Re: xdcam transfer
Love the content browser. Easy just to select the part of clip you want to save, without transcoding to another format.
Re: xdcam transfer
Yes, but you need to transcode if you are editing in Final Cut Pro 7.
And XDCam Transfer lets you do the same "selection" of what you want to import just like Content Browser. |
Re: xdcam transfer
Re: xdcam transfer
I guess my terminology was not correct.
However...in order to use BPAV files in Final Cut Pro 7...you need to...rewrap the .mp4 material into a QT wrapper using XDCam Transfer and there's no quality loss. Not to be confused with "transcoding". |
Re: xdcam transfer
Going back to the original question about the black frames with the X's in them...
This happened to me a while ago with my F3 - after updating the firmware version. Something had changed (presumably in the file headers) and clip browser could no longer 'see' the clips. At that point Clip Browser was already old, so I updated my computer system to (at that point) XDcam Browser and all those clips became visible. Clip Browser was already two generations old when the PMW200 came out - so my best guess is that its files use the newer header structure, similar to the F3, and hence are not directly viewable in Clip Browser. So it really is about time you updated to Content Browser (or even the older XDcam Browser). Of course I no longer have Clip Browser installed anywhere, so I can't actually test whether the 4:2:0 (BPAV) files from my PMW200 would create black frames in Clip Browser. They do work fine in XDcam Browser and in Content Browser. |
Re: xdcam transfer
actually those files came from the pmw200 that was my second camera guy. maybe that's y
Re: xdcam transfer
As a PMW200 owner I can attest that when I first tried to import my PMW200 footage (XDCamEX 35mbps in that case), that I had issues with footage showing up in XDCam Transfer. I installed Content Browser and all my problems went away.
That was my solution. |
Re: xdcam transfer
content browser a free dl?
Re: xdcam transfer
$20, unless you own a PMW200/300 series camera.
Well worth it. |
Re: xdcam transfer
Of course, one COULD argue that IF your second shooter insisted on using his/her own PMW200 instead of a specified EX1 or EX3, there would be a reasonable expectation of them providing usable footage and asking them to transcode the camera card files to .MXF or .MOV QuickTime files with XDCamEX codec footage would seem to be fair in hindisght.
But $20 to me seems like a small price to pay in a professional environment. |
Re: xdcam transfer
I think I must be just to used to using XDCAM Transfer - I can't for the life of me figure out how to get footage from my SxS cards to a portable hard drive to send back to the studio for the post team using Content Browser. I don't see anything obvious (to me) in Export, but I think that's because I'm looking for something with "MOV" in it.
Could someone give a simpleton like me a short step-by-step from the part where I'm viewing the SxS card in Content Browser? Anthony |
Re: xdcam transfer
1 Attachment(s)
Navigate to the directory with the media on your card, click Edit => Copy All and follow the dialog boxes.
Re: xdcam transfer
But first, set your Copy All target in Content Browser => Preferences => Edit tab.
Re: xdcam transfer
Seriously? Copy??? And Final Cut will be able to use it just like that? Dang!!!
Re: xdcam transfer
Just tested it. That certainly copies the entire folder structure and files. MXF isn't usable by FCP7 though. Edit: Nor FCPX evidently.
With XDCAM Transfer, it seems way easier than this. Load SxS, choose location in Preferences, select clips, click Import, MOV files are there. Browser should be as intuitive. What on earth am I missing? |
Re: xdcam transfer
MXF is directly supported by FCPX, yet I am using it. Apple has the official solution here:
Final Cut Pro X: Importing Sony XAVC, XDCAM, XDCAM HD, and XDCAM EX media Content Browser is not needed anymore. No more words. |
Re: xdcam transfer
Awesome. Super easy. Thanks a lot gang.
A |
Re: xdcam transfer
1 Attachment(s)
Anthony: you asked how to copy your SxS cards to the hard drive, which I explained how to do.
From there to import the media, you need to IMPORT the media, which then prepares .mov files in XDCam EX or HD codec (depending on which camera and bitrate) for Final Cut. NEVER import media directly from cards - always transfer to your hard drive first for backup in case something happens to the media files. From FCP 7 (if that's what you are using), choose File => Import => From Content Browser (I believe... I'm not at my edit computer) which opens Content Browser. You can individually Log and Transfer files with in and out points by clicking on the clip in the Explorer and setting in and out points in the Preview and then clicking to Import Into Final Cut Pro OR else you can Import all files in the directory in the Explorer by slecting all (or the ones you want...), right clicking and choosing Import Into Final Cut Pro and following the dialogs. |
| All times are GMT -6. The time now is 05:22 PM. |
