Base to lens center distance? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old June 30th, 2011, 06:08 AM   #1
I've looked through Sony's technical docs and don't see a blueprint type diagram with measurements of critical dimensions and I'm trying to find the distance from the bottom to the lens center to determine whether some equipment I have is compatible. Anyone have a link to a diagram with measurements or an F3 that they could take a minute to measure? +/- a quarter inch or so would be close enough. Thanks.
Old June 30th, 2011, 12:19 PM   #2
Re: Base to lens center distance?
With the camera on a flat surface from the base to the centre of the Sony lens is 73 mm or 2 7/8 inches.
Morton Molyneux is offline   Reply With Quote
Old June 30th, 2011, 12:53 PM   #3
Thank you Morton!
Jim Michael is offline   Reply
