50/60p only over dual link? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old August 11th, 2011, 03:11 PM   #1
Hi there,
I've been trying to get 50p out of my F3 over SDI for some time now without luck. Here are the scenarios:
A) Camera is set to 1080i50, SDI out port (not one of the dual link ports) is used. Connected to my Blackmagic Hyperdeck shuttle. Result is 1080i50.
B) Camera is set to 1080i50, SDI A port of the dual link ports is used. Connected to my Blackmagic Hyperdeck shuttle. Result is a weird squeezed double image. See here: https://img.skitch.com/20110811-fyy8...pwfgsyrdyh.jpg. Seems like the two fields of the interlaced signal get merged into one file.
C) Camera is set to 1080p25, SDI A port of the dual link ports is used. Connected to my Blackmagic Hyperdeck shuttle. Result is 1080p25.
Do I need to have SDI A and SDI B connected to the recorder in order to record 50/60p?
Kind regards,
Chris
Christoph Tilley is offline   Reply With Quote
Old August 11th, 2011, 04:58 PM   #2
Re: 50/60p only over dual link?
Here are the combination of settings to you you 50P:
“Dual-Link & Gamma Select” is set to “3G YPbPr422 & Video”
Format is HQ 1920/50i 1920
Output on SDI "A" will be1080/50P@3G
No output on SDI "B"
You can see all the output combinations in this supplement:
http://ws.sel.sony.com/PIPWebService...upp_Manual.pdf
http://www.LandYachtMedia.com
Chris Medico is offline   Reply
