Upgraded Firmware, now my Hoodman SxS don't work at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old August 27th, 2011, 06:25 PM   #1
Has anyone found a workaround for this? I finally upgraded my F3 to the latest firmware but now my Hoodman SxS SD adapters don't work. If I'd known that the firmware would block them from working, I'd have stayed on the old firmware.
I've looked for the 1.0 version of the firmware to download and install on my camera but it's nowhere to be found.
Since I don't own any genuine SxS cards, I'm actually stuck right now with a camera that I can't use (unless I use an external recorder).
If anyone has a link to the 1.0 firmware, please post it.
Aaron Newsome is offline   Reply With Quote
Old August 27th, 2011, 08:13 PM   #2
Vortex Media
Re: Upgraded Firmware, now my Hoodman SxS don't work
I don't have a link to the old firmware, but all three of my Hoodman SDHC adapters still work fine after I updated my firmware. Have tried different cards in the adapters?
Old August 27th, 2011, 08:44 PM   #3
My MxM adaptors stopped mounting after the 1.10 update, and MxM replaced them with a version that worked.
I used a work around which may help you before that though. If I put the adaptor into the SxS slot without the SDHC card first, then slid the SDHC card into the adaptor while it was in the SxS slot, it mounted and recorded fine. Annoying, but functional.
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old August 28th, 2011, 12:49 PM   #4
You're not talking about the 4:4:4: upgrade are you? If its the other one, my Hoodman adapter works fine with hoodman class 10 cards. Haven't tried any other cards. Are you sure its not your SDHC cards.
Old August 28th, 2011, 04:38 PM   #5
No Leornard, not the S-log update. I'm talking about the free v1.1 update. I'll try the adapter FIRST method.
Old August 28th, 2011, 04:42 PM   #6
I just confirmed that David's workaround does in fact work. Super annoying especially since this has to be done on EVERY power cycle.
Old August 28th, 2011, 04:44 PM   #7
Doug, I don't own any other cards. I only have the 32GB RAW Steel ones that I bought from Hoodman with the adapters.
I emailed their support. We'll see what they say.
Old August 28th, 2011, 07:25 PM   #8
Vortex Media
FYI, I also have one of the 32GB Raw Steel cards, and it works normally with any of my Hoodman and Sony adapters.
Old August 29th, 2011, 05:06 PM   #9
I had the same problem with the 32 raw steel cards and adapters. Hoodman was very nice about sending new ones but I have switched to sony sxs cards because there is money on the line with clients. "If my wife cheats on me I can never trust her again." One failure with a client and they NEVER come back.
Michael Carmine is offline   Reply With Quote
Old August 31st, 2011, 05:26 PM   #10
I tried to contact support but no word back yet. It's been a few days so I'll try again.
Old August 31st, 2011, 09:29 PM   #11
I would call them. Try to talk to Lou if you can. My experience with hoodman support has been nothing less than stellar.
Leonard Levy is offline   Reply
