Any way to output 720p50 to an external recorder? at DVinfo.net
Sony XDCAM PMW-F3 CineAlta
Old December 15th, 2012, 03:36 PM   #1
Hi guys,
I'm wanting to shoot some slow-motion footage, but I can't figure out a way to output 720p50 to my PIX240 in order to keep the 10-bit goodiness from the F3.
When I simply changed the camera's recording format to 720p50, I appeared to just end up with interlaced footage on the PIX.
Any thoughts? Is this even possible?
Cheers,
Mark
Mark Kenfield is offline   Reply With Quote
Old December 15th, 2012, 11:44 PM   #2
Re: Any way to output 720p50 to an external recorder?
As far as I know the cam is real progressive, maybe progressive has to be set on your pix?
Ron Aerts is offline   Reply With Quote
Old December 16th, 2012, 11:15 AM   #3
Instead of leaving the PIX file resolution/rate on "Same as Video Input", what happens if you also dial that to 720p50 ?
Paul Ream is offline   Reply With Quote
Old December 16th, 2012, 11:23 AM   #4
Originally Posted by Mark Kenfield View Post
Hi guys,
Cheers,
Mark
It is possible but you must use the MONITOR SDI port. You can't use SDI A or SDI B. They always output a 1080 signal regardless of the recording frame size of the camera.
http://www.LandYachtMedia.com
Old December 16th, 2012, 02:34 PM   #5
Thanks Chris, I'll give that a try.
