sound-isolated hot shoe mount for Zoom H4n? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old July 21st, 2009, 09:19 AM   #1
i'm using a Canon 5D II. i just acquired a Zoom H4n. is there a sound-isolated hot shoe mount big enough to hold it?
http://piedolatrie.com "if we knew what we were doing, it wouldn't be called 'research'." (attributed to Einstein)
Gaetano Catelli is offline   Reply With Quote
Old July 23rd, 2009, 02:30 PM   #2
the answer!
the answer to my own question is to screw the (supplied) mic stand adapter into the bottom of the H4n, then fit the adapter into a hot shoe shock mount that will swivel. (duh)
Old July 26th, 2009, 09:42 AM   #3
a simpler answer
maybe using some kind of squishy washer between this and the H4n is all that's needed: Tote Vision | HS-1 Hot Shoe Mount | HS-1 | B&H Photo Video
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
