Articulated Arm Noga vs Manfrotto at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
Old November 30th, 2015, 10:53 AM   #1
I need to mount a 7" lilliput monitor to a tripod leg or head. I narrowed it down to
Manfrotto Variable Friction Magic Arm 244N
Or
Noga CineArm DG (Medium) DG9038CA
The manfrotto is heavier and has 5/8 studs on each end.
Old November 30th, 2015, 11:23 AM   #2
Re: Articulated Arm Noga vs Manfrotto
I think if you look at both in person you will lean towards the Noga. I regularly use the Manfrotto arms for rigging but they are much too chunky and big to use for such a small monitor. I don't think you will like them for that application.
http://www.LandYachtMedia.com
Old November 30th, 2015, 12:33 PM   #3
Thx. I noticed the manfrotto is 3x heavier and was thinking the same thing.
I read a review someone warning to be careful not over tighten Noga because threads are aluminum and susceptible to snapping off. Is this a valid criticism?
Old November 30th, 2015, 03:49 PM   #4
It is. Once you overtighten it once you've weakened the metal and it won't hold tight at the joint ever again.
Old December 1st, 2015, 12:50 PM   #5
For what it's worth, these "mini" arms are mostly... underbuilt. Secretly I think they're all made in the same factory in China. Then again, 3/4 of my Manfrotto Magic Arms are dead or in the repair bin as well so... you're kind of damned either way. :)
Old December 14th, 2015, 10:19 AM   #6
I got the Noga and I'm happy with it. Feels solid but without being large or heavy. Although the clamp it's a little tricky tightening it to hold without damaging the tripod leg.
Pete Cofrancesco is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Special Mounts and Applications
