Steadicam Pilot instead of a tripod? at DVinfo.net
Old October 24th, 2007, 09:58 AM   #1
I`m really accustomed to shooting weddings and corporate stuff with my XH A1 with wireless and wideangle attached but I want to accomplish more dynamic shots as well as quicker or more mobile setup than a traditional ENG tirpod.
Would I somehow accomplish those 300mm zoomed-in shots also with Pilot assuming I`m standing still, little wobble would be OK of course.
I`m totally new to stabilizers.
Thanks in advance,
T
Toenis Liivamaegi is offline   Reply With Quote
Old October 24th, 2007, 10:32 AM   #2
Nope, get a tripod first.
A Steadicam is not a subtitute for a tripod.
- Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA
+1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com
Mikko Wilson is offline   Reply With Quote
Old October 25th, 2007, 01:37 AM   #3
Yeah tripod for sure. I`m kind of bored of my own kind of traditional still shots locked on subject(s) I`ve always used a tripod.
I meant that if I want to take my production quality to another level maybe I can benefit from a stabilizer as it seems more productive than a tripod and/or dolly setup.
Cheers,
T
Old October 25th, 2007, 03:25 AM   #4
A Steadicam is an addition to the tripod, not a substitute. It's not good for shooting longer lens material, so unless the wedding party feels happy with having a Steadicam floating 5 feet away from the action it's not good for catching those intimate moments at a wedding.
The best way is to use both and switch between them. There's also a limit to how long you can hold a shot on a Steadicam and you have to be pretty skilled to use one on the fly.
Old October 25th, 2007, 04:06 AM   #5
Images: 10
Although I'll sound like a scratched record for saying this:
http://www.dvmultirig.com/
A great solution for rock steady long shots, creative closeups, interesting angles and movement. And best of all, you will be able to film all day without fatigue.
I shoot long weddings with DVTEC kit. I now have two of them!
http://www.ytvweddingvideos.co.uk/Ne...dul_Ending.mov
Duncan.
Old October 25th, 2007, 04:55 AM   #6
This two-handed rig thing (and the manfrotto Fig-Rig) are great if you don't need your left hand on the camera. Thing is - in the real world out there - you do.
I've stopped using my big L bracket on my Z1. I admit it steadied the odd tracking shot or two, but for most of the time it made small incremental adjustments of the iris control far more difficult to achieve. Same with the fine tuning of the white balance under assign buttons and also the focus assist (as against expanded focus, note).
OK the spring-tube in the kangaroo pouch means your left hand can let go and camera adjustments made, but all the other two-handed devices just mean you can't make camera running changes - it's too much for your right hand to bear.
tom.
Old October 25th, 2007, 05:14 AM   #7
Images: 10
tom.
Exactly,
The DVTEC stuff allows you to operate perfectly with one hand (right usually) on the stabiliser operating a Lanc and the left hand on the focus and iris. You still get steady footage all the way.
Old October 25th, 2007, 05:35 AM   #8
As far as I know Stedicam Pilot isn`t compatible with Manfrotto`s 503HDV head QR for example. Imagine unscrewing the cam for all different shots in live event environment.
That QR problem is the main reason for my post actually.
Going from tripod to Steadicam takes just too much time.
I see two cameras as the only option here.
So I should double the investment when going Steadi, 4K for Pilot plus another 4K for another XH A1 cam. The only other option I see here could be some sort of double QR adapters and such but that`s just plain messy.
T
Old October 25th, 2007, 06:51 AM   #9
You can get QR kits from most tripod manufacturers (including Manfrotto) that allow you switch quickly between your tripod head and the QR reciver on the Steadicam stage without removing the plate from the camera.
- Mikko
Old October 25th, 2007, 08:06 AM   #10
Shooting Digibeta or HDCAM, I sometimes get a second Sony tripod plate so that we can quickly switch from the tripod head to the Steadicam.
You can also buy quick releases from other tripod manufacturers like Ronford, although those particular ones are quite expensive, but a lot less than buying a second camera.
Old October 25th, 2007, 10:21 AM   #11
Yup. Manfrotto/Bogen makes outboard receivers for a number of their quick release plates, so with a very minimal investment you can be up and running with a swappable setup between tripod and Steadicam. Nothing messy about it, and much cheaper than buying another camera.
Shooting uber-long lens stuff with Steadicam is one of those acquired skills--it can be done, but it takes a while to get the technique down. Making subtle pans and tilts in telephoto can be especially difficult compared to tripod.
If you are used to working with manual focus, remember that this will be a less-likely option with your stabilizer (you can do a "set and forget" but that's about it) which makes long-lens work more complicated--having someone suddenly cross the frame that you might want to follow which would normally require a zoomout and a rack focus will be tougher on the rig, you'll have to rely on auto focus and while it's possible to set yourself up with a LANC controller for zoom, it's one more thing to have to connect and disconnect when going between Steadicam and sticks, and more likely a cable that will get forgotten and ripped out when changing over in a panic.
Charles Papert
www.charlespapert.com
Old October 25th, 2007, 03:19 PM   #12
I believe that Charles Papert has mentioned before that about 45% of his Steadicam shots are lockoffs (stable, static shots). Of course, this takes much practice and, like he says, is an acquired skill.
If you're on a Manfrotto head and want to switch between tripod and Steadicam, you can get a Quick Release adaptor that you can put on the Steadicam sled. You can then easily slide your camera off the tripod and snap it into the QR adaptor on the sled and vice versa.
I actually have my stabilizer arm and vest strapped on for the majority of the reception during my weddings and don't use the tripod at all except during the actual ceremony itself. Too many things happen in various locations throughout the reception and a tripod makes things harder to get around and adjust position on the fly. The vest is a godsend as it distributes the weight onto my torso so it's not a chore to keep the rig on ;)
Peter Chung is offline   Reply With Quote
Old October 25th, 2007, 03:34 PM   #13
Duncan, did I miss out on any special prices for the Pro HD at the IOV show?
If so, whats the price now? and who do I order from in the UK? You!?
Tim Sargent is offline   Reply With Quote
Old October 25th, 2007, 04:27 PM   #14
Last time I measured, it was 47.93%...
Charles Papert
Old October 25th, 2007, 05:44 PM   #15
Sorry for the misquote, Sir Charles ;)
Anyways, from the horse's mouth (so to speak), almost HALF of the Steadicam master's shots are lock-off, or tripod-like static shots. So it is possible, with the disclaimer that it takes LOTS of practice and skill to actually pull it off.
