New Flyer at DVinfo.net
Old April 14th, 2008, 07:56 AM   #1
New Flyer
http://www.steadicam.com/userimages/...0Broch_std.pdf
Main changes: extendable carbon fiber post, two section arm that can now handle up to 19 lbs, improved vest , 12/24 volts.
Nick
Nick Tsamandanis is offline   Reply With Quote
Old April 15th, 2008, 01:12 AM   #2
Price?
What is the going price for this new system?
Scott Collins is offline   Reply With Quote
Old April 15th, 2008, 03:38 AM   #3
No, but this rig is now getting close to Archer territory.
Nick
Old April 15th, 2008, 01:22 PM   #4
I posted photos from the press release over here: link no longer valid
MSRP is $7995 (without batteries), and $9500 with a 2 x Power-Cube battery kit.
Shipping now.
- Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA
+1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com
Mikko Wilson is offline   Reply With Quote
Old April 15th, 2008, 08:26 PM   #5
That's really good news, I thought it would be way more expensive then that.
Nick
Old April 15th, 2008, 10:05 PM   #6
Unfortunately, the same lower sled structure which hinders dynamic balancing--wish it had been redesigned along the lines of the Pilot.
Charles Papert
www.charlespapert.com
Old April 15th, 2008, 10:56 PM   #7
I'm with you there Charles, but 19 pounds capacity at that price seems like great value, should just scrape through with a fully kitted Red camera?
Nick
Old April 15th, 2008, 11:16 PM   #8
"fully kitted" is a complicated statement Nick--once you enter the 35mm optical arena, the lenses start to become a major weight component depending on type. Super Speeds, no problem...Master Primes or lightweight zooms, could be a problem. And consider 1 or 2 (or even 3) motors, motor driver/receiver for same, downconverter, transmitter, mattebox, Cinetape...things add up quick. And all this assuming you power the camera off the sled--flying the battery would be a bad idea for a small rig.
I would actually say that a stripped down RED would be viable, but a fully-kitted one would require a larger capacity system, at least 25 lbs and more appropriately 30 to be able to handle whatever configuration is required. As a DP I would be very discontent if my operator was unable to accommodate the tools required to do the job.
Charles Papert
Old April 15th, 2008, 11:27 PM   #9
Thanks again for the info Charles, will keep in mind.
Nick
Old April 16th, 2008, 01:19 PM   #10
See they also did a redesign of the arm. Nice but I'm with CP on this one.
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old April 19th, 2008, 08:07 PM   #11
Looks like there are three versions of the new Flyer, standard, hi-def and a Red camera version: http://www.youtube.com/watch?v=c6G1iRGrCTk
Nick
