SteadiCam JR setup with PD 150 at DVinfo.net
Old July 30th, 2004, 06:58 PM   #1
Hi guys, I was given a SteadiCam JR unit from a friend, but I don't have the "Cookbook" which comes with the unit.
Does anyone have the specs which are recommended for a PD 150?
Any suggestions on set-up and use would also be greatly appreciated!
Tony Singh is offline   Reply With Quote
Old August 9th, 2004, 11:35 AM   #2
Tony,
You can acess both the Steadicam JR Set-up and Operation manuals online at http://www.steadicam.com/jr_manual.htm. I don't see the Cookbook, but given fact that the PD150 wasn't around when the Steadicam JR came out it wouldn't be listed, anyway, unless the Cookbook has been updated since then.
You also need the special weight kit for the PD150. You can get it from B&H (http://www.bhphotovideo.com/bnh/cont...=250943&is=REG.
Christopher Lefchik is offline   Reply
