Running video to a bottom mounted LCD on a Glidecam at DVinfo.net
Old August 17th, 2005, 04:45 PM   #1
Hey, I searched all over for this and coundn't find anything... so...
What's the best way to get a video signal to the bottom of a Glidecam 4000 Pro sled? I seems to me it might be best to drill a hole in the top and bottom of the center post and run it through the there...
Anyone...
Also, I'm asumming you can drop some weight on the front of the sled once the LCD is there, right? I've got it balanced and stuff with my XL1s, just don't have the monitor on. I can't imagine adding too much more weight, so I was just planning on taking a few of the washers off the front...
Kevin Dooley
Media Director, Pantego Bible Church
Kevin Dooley is offline   Reply With Quote
Old August 17th, 2005, 05:33 PM   #2
Kevin:
I'm not a Glidecam expert per se, but...
yes and yes.
Charles Papert
www.charlespapert.com
Old August 17th, 2005, 09:48 PM   #3
Kevin,
I just did that with my sled which is similar to the Glidecam. In my case, I had to take all the weights off the front as I hooked the battery to the back of the monitor and mounted in on the front. I then had to add a bit more weight to the back to equalize it.
I had to do this as my battery cable is so short that I couldn't mount the battery on the rear of the bottom plate. I suppose I will make a longer cable so I can put the monitor on the front and the battery on the back.
I did notice that with the extra weight, my sled was a bit more stable but I do have an arm and vest to support it so a bit more weight is OK.
Charles,
How's your ankle? Remodel? Video?
Tery
He's only mostly sDEADy.
sort of from "The Princess Bride"
www.indicam.com
Terry Thompson is offline   Reply With Quote
Old August 17th, 2005, 10:01 PM   #4
Terry:
Healing slowly. Endless. Once I'm mobile again.
..but thanks for asking!
Charles Papert
Old August 17th, 2005, 10:33 PM   #5
Originally Posted by Charles Papert
Terry:
Hi Charles,
Sorry to hear your injury. Wish you recover soon.
Regards
Leigh
Leigh Wanstead is offline   Reply With Quote
Old August 17th, 2005, 10:57 PM   #6
thanks...she's a beaut. Itching to get back to work again.
Charles Papert
Old August 18th, 2005, 12:00 AM   #7
Hope you can get all done that you want to.
Tery
www.indicam.com
Old August 18th, 2005, 08:45 AM   #8
Which LCD monitor and battery are you guys using?
George Creasman is offline   Reply With Quote
Old August 18th, 2005, 08:48 AM   #9
I'm using a modified Panasonic 7" widescreeen LCD. It has a mount on the back of it to run off the same batteries as my XL1s.
I got it from a company called Nebtek.
Kevin Dooley
Old August 18th, 2005, 11:35 PM   #10
Nebtec NEB50 5" (looks great in full sunshine) with the Panasonic Li-Ion battery adaptor. The battery is the stock one (1600 mAh) that comes with the camera. I bought the 5000 mAh battery for my DVX-100a off of dvxuser.com because of the extra shooting time if allows. A great value!
Tery
www.indicam.com
Old August 22nd, 2005, 11:28 AM   #11
By all means, drill a hole...just make sure you carefully deburr it and file the cut edges down (or use a rubber grommet) so that your cable doesn't catch on the edge and wear down over time.
Casey Visco
Glidecam Industries, Inc.
Casey Visco is offline   Reply With Quote
Old October 8th, 2005, 12:31 PM   #12
I recently attached this monitor w/battery pack to the bottom of my Glidecam 2000 Pro (I use a Sony VX1000):
http://www.bhphotovideo.com/bnh/cont...ughType=search
It's now pretty heavy, but my optional forearm brace helps. I think I'll need to purchase a Glidecam Smooth Shooter system when I can afford it to sustain longer tracking shots without wearing down my arm.
I screwed a hole on one end of the included "table" mount (came with the LCD) and placed the screw through it (I used the G2K screw). I then used one strip of velcro to secure the other end of the table mount. I then used two strips of velcro to secure the battery pack on the opposite side and attached G2K discs to balance the weight. It worked perfectly for me.
Some pics:
http://i22.photobucket.com/albums/b3...red/G2K003.jpg
http://i22.photobucket.com/albums/b3...red/G2K002.jpg
http://i22.photobucket.com/albums/b3...red/G2K001.jpg
Armin DeFiesta is offline   Reply With Quote
Old October 8th, 2005, 02:54 PM   #13
Armin:
I see that you have a very short cable between battery and monitor, but you still could rotate the battery 90 degrees, which would probably eliminate the need for the two weight disks (every little bit helps) as you are redistributing the battery's weight further back.
An even more useful project for down the road would be to mount both the monitor and the battery further apart, extended off the front and back respectively. This will give you an amazing amount of added inertia which will make a significant difference in keeping the rig steady, while not affecting the overall weight significantly (outside of whatever plate you need to use to achieve the mounting). This may also help with glare on the monitor as you may be able to set it less horizontally.
If you are now finding that the system is bottom heavy, one solution is to move the monitor up closer to the camera, which will also help with the tilt issue.
Charles Papert
Old October 8th, 2005, 07:05 PM   #14
Armin:
I took your advice Charles and it worked. It's now lighter and was still easy for me to balance. Thanks!
Old October 8th, 2005, 08:43 PM   #15
Glad it worked out...!
Another step to reduce weight would be to power the camera off your battery at the bottom, but this would require a voltage converter such as this one which may possibly weigh as much as your GL2 battery...!
Charles Papert
Charles Papert is offline   Reply
