Glidecam 2000 with a GL-2 at DVinfo.net
Old December 29th, 2006, 08:37 PM   #1
Hello,
I'm really having bad time of balancing my Glidecam and GL2. I'm using a WD-58 wide angle converter and a BP-945 (large) battery with the setup. If there is anyone out there who is using this setup or close to it I would really appreciate some help or tips.
Thanks in advance,
Jerome
Jerome Terry is offline   Reply With Quote
Old January 10th, 2007, 11:48 AM   #2
That might be too close to the max weight, you'd have an easier time balancing the 4000.
I think you can just buy more weights and the internal tube for the 4000 (which is longer)
Brent Graham is offline   Reply With Quote
Old February 25th, 2007, 06:53 AM   #3
That is true. I had the canon gl2 and now the a1 and both balance with the 2000. But now with the 4000 I realized that is a lot easier to balance with.
Jose Ortiz is offline   Reply With Quote
Old March 1st, 2007, 10:52 PM   #4
Thanks for the info guys.
Old March 7th, 2007, 03:19 PM   #5
I haven't used the gl-2....but I have used my vx-2000 with big battery and century optics .55x lens on it. It requires 6 weights total(3 each side) and the pole out at the very limit.
Eric Stemen is offline   Reply
