Canon EF 35-350mm f/3.5-5.6L USM Lens at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > Still Crazy
Still Crazy
You say you want resolution? The whole world is watching these digicams.
Old August 1st, 2004, 10:09 AM   #1
I am planning to purchase my first high-end Canon lens (most of my stuff now is non-L and/or Tamron). When shooting at the motocross track I would like to have one lens that allows me to zoom a good distance across the track, but at the same time can take the occasional candid wide angle shot.
The Canon EF 35-350mm f/3.5-5.6L USM Autofocus Lens seems to fit that description nicely. What do y'all think?
Josh Allen is offline   Reply With Quote
Old August 1st, 2004, 10:16 AM   #2
Warden
This lens is discontinued and replaced by the 28-300mm IS L lens. the addition of the IS is welcome but I would consider the relatively slow maximum apertures (f/3.5 - f/5.6) a drawback for any type of motorsports. My first preference would be the 70-200mm f/2.8 IS L series zoom. This is a staple for sports photographers and considered my most pro's one of Canon's best lenses. If you compare the MTF charts you'll see the lenses aren't really in the same class.
Jeff Donald
Carpe Diem
Old August 1st, 2004, 01:09 PM   #3
Thanks Jeff.
How long ago was the35-350 discontinued? B&H still has it listed as in stock, but perhaps those are just left overs.
My only complaint about the 70-200 is the more narrow zoom range. But, you are probably right about the max aperature.
Hmm...decisions, decisions.
Old August 1st, 2004, 01:13 PM   #4
Warden
The lens was discontinued this past spring, when the 28-300mm was introduced.
Jeff Donald
Carpe Diem
Old August 1st, 2004, 07:30 PM   #5
Josh,
I have both the 35-350MM and the 70-200mm 2.8, I also shoot a lot of motor sports. Of course Jeff is correct. I use the 70-200 much more at the track. Another consideration is that the 1.4 and 2x extenders work with the 70-200 but not the super zooms. The value of the 35-350 and and it’s 28-300 sequel is not to be underestimated. I often advocate that one of these lenses should be the first lens purchased when you want to start moving up to good glass. It covers such a great focal range it can keep you shooting sharp pictures while you wait to invest in other expensive lenses. I would rather own one, slow and heavy, Canon 35-350mm L series lens than 4 Tamrons or Sigmas with faster apertures. I know that upsets some people, I’m not trying to knock the companies or users of those products. In my opinion you just can’t manufacture quality glass cheaply.
Even though I have 3 of Canon’s 2.8 zooms, I still use the 35-350mm. I think of it as my utility lens, the versatility is amazing, it is tack sharp, and I could use it for a boat anchor if I needed to. It is an excellent choice for your first high end lens.
Also, when I shoot motor sports, I turn image stabilization off most of the time.
www.CorporateShow.com
Old August 1st, 2004, 08:20 PM   #6
"Also, when I shoot motor sports, I turn image stabilization off most of the time."
Steven, I do not do much photography of moving subjects so this may seem like a stupid question. But, why would you turn IS off?
Darrell Hinton is offline   Reply With Quote
Old August 1st, 2004, 09:43 PM   #7
Not a dumb question at all. With IS on I can hand hold my 70-200 at 200 and take a sharp picture (of a still subject) at 1/30 of a second, that is impressive technology. That’s when it works the best.
When shooting motor sports the IS usually takes to long to activate, I am often shooting before it kicks in. You can see it activate in the viewfinder when panning, the image “jumps”. If you are in a situation that does not require IS you are placing extra drain on batteries and asking the lens and cameras processor to perform an extra function that is not necessary. I turn it off and on a lot. For example, if I am trying to freeze action at 180 MPH in daylight it is off. If I am using a slow shutter to blur everything but the car, it is on, this works best when you have a predictable line to pan, and time to pick up the car early. Racing generally happens to fast for IS, it is off most of the time.
Steve
Old August 1st, 2004, 09:51 PM   #8
Warden
IS can also misrepresent your framing on pans. You think you have your subject (car) framed correctly , then the IS corrects for something and the subject gets moved off the framing.
Jeff Donald
Carpe Diem
Old August 1st, 2004, 10:17 PM   #9
Steven and Jeff, thanks for clearing that up for me.
Old August 1st, 2004, 10:51 PM   #10
Yes, thanks to both for the great input.
Steven, the benefits you mention regarding the 35-350/28-300 are precisely the reasons I was thinking of going with it. But it is interesting that you primarily use the 70-200 at the track.
Is the speed (as Jeff mentioned) the main reason you use the 70-200 at the track?
Old August 2nd, 2004, 01:35 PM   #11
The speed is only one reason. The 70-200mm 2.8 is a superior lens in several ways. It is brighter, lighter, and easier to handle. The one touch zoom is much better than the clunky push/pull zoom on the 35–350mm. The big zoom is a compromise, not the ultimate solution. It is a great place to start.
And Jeff brought up the ultimate flaw with IS, composing a shot of anything at 180MPH is tough, the last thing you need is a lens "feature" suddenly changing it for you.
Old August 2nd, 2004, 07:54 PM   #12
Hmm...more things to think about.
It appears you can buy the 70-200 for a few hundred less if you get it without IS. Would that be advisable given the typical shooting situations I am in?
Sorry for all the questions :)
Old August 20th, 2004, 10:56 AM   #13
Josh,
I’m sorry it has taken me so long to reply, I pop in and out of here as my schedule permits. I think the 70-200mm without IS is the previous model, it may be hard to find new. I would say get the lens with IS, it is a nice feature; you just need to know when to use it. Did you buy a lens already? Ask all of the questions you want.
Steve
Old August 20th, 2004, 11:58 AM   #14
Warden
Canon still makes both versions of the 70-200mm f/2.8 L series.
Jeff Donald
Carpe Diem
Old August 21st, 2004, 12:14 AM   #15
Thanks again Steve and Jeff, you guys are really so helpful!
I have not yet purchased, but I hope to do so this coming month. Based on both your recommendations I am fairly certain I will get the 70-200 f/2.8 L with IS. Hopefully I will be posting some pics taken with it soon.
Thanks again!
  You are here: DV Info Net > And Now, For Something Completely Different... > Still Crazy
