D1X Problems at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > Still Crazy
Still Crazy
You say you want resolution? The whole world is watching these digicams.
Old April 9th, 2005, 09:11 PM   #1
D1X Problems
Does anybody have this camera? I think my monitor has gone out? Anybody had this problem?
kc
kc
Kevin Crisp is offline   Reply With Quote
Old April 10th, 2005, 06:53 AM   #2
RED Code Chef
Do you have a link to this camera? Who makes this? I've never
heard of a D1X before.
Rob Lohman, visuar@iname.com
Old April 11th, 2005, 06:14 AM   #3
reply
Nikon D1x. You should be able to find info on it.
kc
Old April 11th, 2005, 05:14 PM   #4
Kevin: I moved this thread to the still camera forum. Hopefully you'll get an answer here.
Old April 14th, 2005, 09:49 AM   #5
Retired DV Info Net Almunus
Kevin,
By "monitor" I assume you mean the LCD display at the camera's back?
The D1x is the predecessor to Nikon's current D2X, a pro-level digital SLR still camera. I think you may have more luck looking for answers at DPreview's Nikon D1/D2 forum, although it the LCD simply stopped working you'll obviously have to send it for repair.
Good luck.
Old April 14th, 2005, 12:44 PM   #6
I have found multiple bugs in both the D1 and D1x after extended use. No LCD problems though. Our main problems have been with exposure readings, both flashed and non-flashed. Service didn't seem to help much. It just seemed to degrade some over time. The meter can be off , mostly under, more than a stop sometimes (spot meter on 18% grey, sunlight). Anyone else notice this?
Matt Manning is offline   Reply With Quote
Old April 15th, 2005, 10:20 PM   #7
I do not own a D1/D1H/D1X (I use a F5 & D2H) although I have played with a friends D1 and D1X.
It definitely sounds like your D1X needs to be sent in. I have not herd of any issues with the LCD screen.
I have also not herd of any exposure problems with the D1 series cameras. I know that with the D2 series that Nikon have made the camera underexpose by 1/3 of a stop to help hold highlight detail. Back when I worked at a Nikon Pro dealer I remember a good customer who did not align his lens up with the mount and bent the prong that steps the aperture down. This caused his D100 to under expose by a 1 1/3 of a stop.
The old D-TTL flash definitely is not as good as TTL on film or i-TTL on the D2. I have herd of lots of people having to shoot a scene or subject multiple times when using flash on D1 series. I also herd that AA auto mode works better then D-TTL in a lot of situations.
I also recommend that you both check out www.Nikonians.org. It is wonderful resources vary similar to DVinfo but all Nikon.
Best of Luck,
Alex
Alex Ratson is offline   Reply
  You are here: DV Info Net > And Now, For Something Completely Different... > Still Crazy
