#16 |
you're comparing apples to oranges. All of the DSLR cams have sensor sizes that are *close* to 35mm. APS-C which is the Canon size is close to 30mm. The consumer or prosumer non-DSLR cams are going to have consumer-sized sensors--approx 1/3" to 1/2". No comparison as far as Depth of field and latitude are concerned.
#17 |
MPS Digital Studios
Gotcha, thanks.
hwm
My Final Cut Pro X blog |
#18 | |
#19 |
OK, maybe I'm not completely "getting it" when it comes to DSLR's. I was in Circuit City today so I just played around a little with the well-worn floor models. None of the Nikon's showed an image on the LCD while in camera mode, which I guess makes sense because the mirror is blocking the CCD.
So I tried locking the mirror up on the D80. When I did that, nothing worked on the camera at all. I was assuming that this would let you use the camera like one of the consumer cameras and see the image on the CCD. Guess I was wrong about that? One of my concerns with a DSLR is that I like to take photos of our performance out in the audience, and the mirror/shutter noise on a film SLR is not acceptable for that. This is one of the nice things about using a digital camera.... it's silent. Can any of the DSLR's operate in "silent mode"? Also (maybe this has something to do with the condition of the Circuit City display models) the image in the D50's viewfinder was considerably dimmer than what I saw on the D80 and D40. The D40 and D50 had the same cheap 18mm-55mm (I think) lenses so I don't think that was the problem. The D80 had a cheap 18-135mm lens IIRC. I was really not impressed by these lenses and this makes me think that it would be a big advantage to use the old manual Nikon optics on a DSLR. |
#20 | ||||
(Sorry for my english, but when it comes to technical details like this...)
Keep rolling Rainer |
#21 |
Wow, thanks a lot Rainer. I don't see any problems with your English whatsoever, those were very clear explanations!
Obviously I need to get to a camera store where someone can answer my dumb questions in person... looks like I need to stop by B&H the next time I visit NYC :-) |
#22 |
MPS Digital Studios
I keep forgetting B&H is big in photo equipment, too. I'm about to get a new job, so after I take care of some expenses from my film, I'll likely buy the Canon Rebel.
heath
#23 | |
One more thing: some of the Olympus DSLRs do have what's called a live preview on the monitor. So if this is something you would like, you should probably have a look at the Olympus range of DSLRs.
#24 | |||
The solution is to buy a camera sound "blimp", but again, much of the noise travels through the lens. In your situation, I think a box filled with Auralex and lined with metal or lead (dense metal that is available in plastic-sealed sheets) would take the bite out of most of the sound. Quote:
#25 |
Thanks a lot Gints! I need to spend a little time learning about the state of the art with DSLR's. I used to do a lot of photography going back to the 1970's when I had a darkroom and a couple Nikons, but I did less and less as the years passed. Then when I got my first digital camera in 1999 I packed up all my film cameras and haven't touched on since :-)
