Satellite Uplink Equipment List? at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > Taking Care of Business
The pen and paper aspects of DV -- put it in writing!
Old May 9th, 2010, 02:37 PM   #1
I realize their are costs to uplinking, and many factors to consider. For now, I would like to locate a list of the equipment that is needed to set up an uplink in a vehicle or fixed location. Thanks for any info and input you can provide.
Lisa
http://www.victoryNOWfilmsandtv.com
Lisa Bennett is offline   Reply With Quote
Old May 9th, 2010, 03:33 PM   #2
There are companies that sell complete turnkey systems. I'd take a look at their websites and start my list by seeing what equipment they offer.
Chris Davis is offline   Reply With Quote
Old May 9th, 2010, 03:44 PM   #3
Hi Chris,
Thanks for the reply. I'm searching the net for info and tutorials but have not seen a list of the actual equipment needed to send a taped program and/or live show to the uplink. I have found out a few of the items needed such as router, modulator, up converter, power amplifier.
LB
Lisa
Old May 9th, 2010, 06:41 PM   #4
The equipment list is varied depending upon power output, redundancy, input requirements and a host of other factors. You need to go to a company experienced in building ground based facilities or uplink trucks. At the very least if you don't have experience in this field then you need to hire an experienced engineer to help you spec and design your system. This is not information that can be gleaned from "internet tutorials" or from web searches.
If it's only a temporary need then just hire an uplink truck for the event. It's much more cost effective and you'll have experienced pros handling the technical details.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old May 9th, 2010, 08:20 PM   #5
I agree it is a specialty all it's own. Looking to learn all I can about the process.
LB
Lisa
Old May 10th, 2010, 07:29 AM   #6
It would be much cheaper to purchase a used uplink truck that is being replaced, than to build one from scratch as they are very expensive to build.
FYI... You will also need to be licensed to operate said uplink truck.
David W. Jones
www.joneshdfilms.com
Old May 10th, 2010, 09:35 AM   #7
Location: London, Milton Keynes, Bedford UK & Beijing, China
I'm not sure if this is strictly what you're after, but BGAN systems and M-Link are great for uplinking news footage from remote environments.
Have a look at :Livewire Digital Ltd - Home page
Of course, if it's a live show you're uplinking with several cameras etc then that takes you into another league.
Sean
Sean Walsh
http://www.visionworkstv.co.uk PPro, Z1, EX3 - Currently in Beijing at CCTV-News
Sean Walsh is offline   Reply With Quote
Old May 11th, 2010, 12:12 PM   #8
When I was working for the Canadian national public broadcaster, our Sat truck was worth between $1-1.5 million dollars, or so I was told...
Not only do you need to be licensed to OPERATE the truck, you need to buy sat time as well. We were partitioned onto one of the ANIKs if memory serves correctly...
As well, due to the onboard hardware necessary, NORMALLY a dually truck/van chassis is required, which then necessitates additional licensing requirements. We had ours built on a non-dually E350 chassis and had some issues with weight at the tires until that got worked out.
  You are here: DV Info Net > And Now, For Something Completely Different... > Taking Care of Business
