Photoshop curves for film ? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 27th, 2004, 06:53 PM   #1
Hi,
I'm trying to process some video frame grabs with Photoshop.
I'd like to apply the film s-curves by selecting from a number of
Presets. The .MAP files on this site look right, but with X and Y axes swapped.
Check the film correction curves here :
http://www.aim-dtp.net/aim/techniques/photograph/
Does anyone know how to swap the axes or have any other curves or maps files? If not, I'll just tweak the dozen or so files
and make them available.
Thanks !
Gints Klimanis is offline   Reply With Quote
Old January 27th, 2004, 09:35 PM   #2
Gints: I'm not sure if this is it, but here goes...
Looking at the Curves dialog box in Photoshop, you should have the two greyscale bars - a vertical one, located to the left, and a horizontal one, at the bottom of the curve lines.
On the horizontal one, there should be a little white button looking thing in the middle, with two arrows pointing left and right. You should be able to click the two arrows to swap the axes.
Hope that helps!
,Frank
Frank Ladner is offline   Reply With Quote
Old January 28th, 2004, 03:55 AM   #3
RED Code Chef
A lot of tweaking like that can be done in an NLE which has
good curve tools (like Vegas and Avid). I'm not sure what (good)
tools Premiere has.
Rob Lohman, visuar@iname.com
Old January 28th, 2004, 02:45 PM   #4
Frank,
Thank you for the suggestion. I tried the little arrows, but they also include an inversion. So, the "little arrow" process seems to mirror (swap -N with + N) both x and y around an origin in the middle of the grid, which isn't quite the same as swapping X and Y with the origin at the lower left of the grid.
Thanks. I just used the polynomial mode to approximate a couple of curves, but I was hoping to tweak the real data.
Old January 29th, 2004, 12:44 AM   #5
<<<-- Originally posted by Rob Lohman : I'm not sure what (good)
tools Premiere has. -->>>
Almost nothing by itself, but combined with a Canopus card it has beautifully working YUV-curves along with other great tools.
Jami Jokinen is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
