New ArriHD prototype at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 30th, 2004, 05:29 PM   #1
Very informative article in the February 2004 issue of American Cinematographer detailing the prototype of the Arri D-20 HD camera. It appears to be the first practical HD camera to incorporate an optical viewfinder and shutter for improved viewing and 6 megapixel 24x18mm CMOS sensor which allows PL mount lenses to be used with no magnification in field of view. The Dalsa camera had similar specs but a much less friendly profile physically, whereas the D20 follows the form of the Arri 435, replacing the mag with a black box containing the electronics. Variable frame rates of 1-100 fps are supported. Arri is reporting 10 stops of latitude at current time but hoping for 12 stops in the final release. Various output options will be available including raw mode or HD-SDI; a "live processing" mode outputs via DV stream.
Even in prototype (read: chunky) form, the footprint is well within reason and one can only imagine it will improve before release. This looks to be an exciting addition to the HD production world, it should integrate with film accessories much easier than, say, the Panavised Cine-Alta and offers the depth-of-field of a full-sized sensor eliminating the need for an outboard system like the PRO35. Considering that Arri has continually professed their allegiance to film technology, this is an impressive digital acquisition debut. Not that they are changing their position--Franz Kraus, general manager of the Arri Group is quoted as saying "It is clear that the performance of film cameras cannot currently be met by digital cameras...digital acqusition has become a viable alternative, even if it means tolerating an 'electronic look' and the handling limitations of the current equipment".
Charles Papert
www.charlespapert.com
Old January 30th, 2004, 06:58 PM   #2
I'm in shock!, What can i say?
I was just moaning on about wanting Full sized (35mm) sensors for digital video (ie not Dalsa) and now This!!
This is really exciting.
Please keep us updated on this camera.
I know its very early but is their any links/ pics any kinda info out there yet?
Thanks Charles
----------- Anhar Miah
Anhar Miah is offline   Reply With Quote
Old January 30th, 2004, 07:05 PM   #3
Here's a pretty good article and picture of it.
http://www.arri.com/news/ibc/ibc03_ab/d_20.htm
Don Mahr is offline   Reply With Quote
Old January 30th, 2004, 07:08 PM   #4
Just found it, this must have gone up recently. Second item down.
Charles Papert
Old January 30th, 2004, 07:23 PM   #5
Thanks, that was really insightfull!
It seems there are still some way to go, but its starting and thats a good thing.
The data storage seems the biggest obstacle,
maybe they could use some sort of Lossless compression.
any way thanks for the link
Old February 3rd, 2004, 01:47 PM   #6
RED Code Chef
You mean I actually missed that @ IBC 2003? Dang. Sounds very
interesting indeed! Is the Cine-Alta not full 35mm?
Rob Lohman, visuar@iname.com
Old February 3rd, 2004, 05:51 PM   #7
Barry Wan Kenobi
The CineAlta? No, that's HDCAM, which is 1920 x 1080 off the camera head, but records to tape at 1440 x 1080. Nowhere near film resolution. And the sensor sizes are 2/3" CCD.
Still, looks pretty good on the big screen.
Old February 3rd, 2004, 06:06 PM   #8
RED Code Chef
2/3" CCD? Wow. I wouldn't have thought that. Thanks!
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
