-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   Does anyone know how to solve this keyframe problem in Premeire Pro? (https://www.dvinfo.net/forum/techniques-independent-production/537679-does-anyone-know-how-solve-keyframe-problem-premeire-pro.html)
Ryan Elder November 9th, 2020 02:02 AM
I have an effect I want to that involves using key frames. Adding the keyframes to do the effect causes the footage to have to pre-rendered of course. The bar on the timeline is red, and I have to pre-render so the bar is green and everything plays much better.
However, after I pre-render, the keyframes all reset to the defaults that the footage was at before I changed the keyframe settings. I haven't had this happened before and cannot find any help online on how to fix it. Is there a way to pre-render, without the keyframes being reset to default?
Paul R Johnson November 9th, 2020 11:54 AM
Re: Does anyone know how to solve this keyframe problem in Premeire Pro?
What do you mean they return to the defaults the footage was at before? What are you actually doing? Mine don't reset on the effects I use? which process is it?
Ryan Elder November 9th, 2020 12:25 PM
I am doing a title sequence where the titles move onto the screen. I am using key frames to move them. But when I pre-render the sequence, all the titles are not still because the keyframes have moved back to the positions and are not moving after, and they are in the positions they would have been, had I not added keyframes. That's what I mean by them resetting to default positions.
Paul R Johnson November 9th, 2020 05:51 PM
I’m afraid I can’t replicate this Ryan. Have you changed anything? My key frames remain. Rendering makes no difference. However moving a few titles shouldn’t stress your machine unless you’re doing something very complicated.
Ryan Elder November 9th, 2020 10:28 PM
Oh okay thanks, for trying. No, I cannot think of anything else. I am moving the title over footage of fire. The fire has an alpha channel in it, because it's from Action Essentials II, but all I can think of that may be unique is there is an alpha channel. I cannot think of anything else.
Paul R Johnson November 10th, 2020 02:00 AM
Hang on. Yo mean the fire is rendered so it’s smooth, but the key frames in a simple overlaid title vanish? That sounds like a file error. I’d rebuild that section before you go an6 further in case it wrecks the edit that follows. Go back a few save versions and do it again. When something like this happened to me I had to re-edit a few days worth once when the problem which was small, became deadly.
Ryan Elder November 10th, 2020 11:41 AM
Oh okay thanks. I went back to a previous saved point and then rebuilt it it's the same thing after I render and the keyframes reset. Is there anything else I can do?
Paul R Johnson November 10th, 2020 01:07 PM
I won't have the image files, but I can try to load it up and see if there's anything I can see without the files? Feel free to send me the premiere file and I'll have a look.
Ryan Elder November 11th, 2020 02:52 AM
Oh okay, thank you very much. Well I am not sure how to send an editing file though.
However, I tried exporting the video, without it being pre-rendered. So I guess all I have to do is not have the title sequence pre-rendered, so it plays smooth, and just keep it rough with a red bar, if that makes sense, because then the keyframes will still be there... And just keep it non-pre-rendered, because then it will export with the key frames properly?
If that makes sense...
Paul R Johnson November 11th, 2020 02:57 PM
I'm guessing you don't have a decent graphics card on the list? I never bother to render anything as it plays fine on the fly. Glad you sorted it
Ryan Elder November 11th, 2020 09:06 PM
Oh I'm not sure, my card has seemed to work fine for the most part. I was told that if you export the movie, before pre-rendering, that it could cause problems in the video though, if that's true?
Paul R Johnson November 12th, 2020 03:01 AM
No rubbish! When exporting it has to render it, so it takes longer. Rendering just helps the editing speed. In premiere if your card is on their list and supports on card processing, rendering becomes a thing of the past. If you have too much clever stuff the processor struggles with, rendering is a part solution. With an ordinary graphics card rendering is necessary to just get it to play, but with a proper graphics card with on board processing, you do things, press play and it does. You forget about all the cups of coffee you used to have to make while you waited.
Ryan Elder November 12th, 2020 06:55 PM
Oh okay that's what I thought. Thanks! Well as long as not pre-rendering will work to keep the keyframes where they are without any additional problems.
Paul R Johnson November 13th, 2020 02:18 AM
Don’t forget you haven’t solved the problem, just found a good workaround.
