DigiEffects Cinelook at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 6th, 2003, 12:37 AM   #1
I tried a demo of DigiEffects Cinelook plugin for AfterEffects and Premier, and so far it's the closest thing to film I've ever seen from a video camera and is real easy to use. Only downside is the rendering time (.5 frames per second on my 2 GHz PC).
Anyone else have good experiences with this package?
Peter Moore is offline   Reply With Quote
Old January 6th, 2003, 02:01 PM   #2
I have used Cinelook extensively in the past and in the beginning I was just as impressedas you are now I think. I feel the presets are all a bit drastic, and would benefit from reducing the amount and size of grain.
What's left in the end is a really nice (but expensive) curves filter, and the last years I've been using just the curves and levels filters in AE to the same effect. I don't add much grain (how much grain shows in a 35mm to video transfer anyway...), and if I do, I often get by using AE's noise with a slight blur. I apply a large amount of noise to a solid, and then apply a slight blur to the noise layer. Then experiment with transfer modes for this layer, and reduce the transparency to a minimum. If you need a larger grain size (for 16 or 8 mm effect), scale up the noise layer.
Looks just as good as Cinelook and renders a LOT faster. Just make sure you are working with full frames, not fields, so you might need to separate fields, or de-interlace.
Bar3nd
www.raamw3rk.net
digital storytelling and vfx
Barend Onneweer is offline   Reply With Quote
Old January 6th, 2003, 05:23 PM   #3
That's real interesting, I'll have to try that. Thanks for the advice.
I do notice the presets are drastic and so I will have to experiment a lot.
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
