Depth of Field at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old December 31st, 2006, 01:09 PM   #1
Depth of Field
I was just curious if shooting indoors would counter depth of field problem when using digital instead of film.
Sean J. Manning is offline   Reply With Quote
Old January 2nd, 2007, 06:47 PM   #2
To what problem are you referring? The depth of field is only changed indoors if the iris is opened because there is low light available. Most digital cameras have a very broad/wide depth of field in almost all conditions. It is possible to use neutral density filters outdoors to be able to open the iris more to get a more shallow depth of field (background out of focus), but it is not as apparent as in a 35mm film camera.
Old January 3rd, 2007, 06:16 AM   #3
To have the least depth of field you need to open the iris wide open. This is easier indoors because there is less light. Outdoors you can use ND filters to reduce the light.
Still more difficult, but not because of being digital, but mostly because of the small size of most digital cameras sensors, 1/4" 3/8" etc.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
