problem exporting 24f in PP2 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 9th, 2007, 10:53 AM   #1
After shooting 24f footage on a Canon xh a1, capturing using the Adobe preset which I downloaded from Adobe, and editing, when I went to export to dvd their was stairstep type artifacts on the dvd playback only. When i exported to WMV it was fine, and everything looks great on an ntsc monitor when playing back from time line.. I know PP2 doesn't support export to tape from 24f, but it appears somethings funky with DVD export...as least in my setup. Any help greatly appreciated!
Peter Zipfel is offline   Reply With Quote
Old January 10th, 2007, 12:24 AM   #2
Peter
May I ask what program were u using to do the authoring. What was the compression.
You said that PP2 doesn't support export to tape using 24f.
What settings did u use to capture and edit the raw 24f.
Please note that from the PP2's timeline, you can export to tape. Make sure that if you are exporting to tape, you use a camcorder that is capable of capturing 24P or 24f.
Canon Xl2, Adobe Premier Pro 2.0
Eb Samba is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
