Widescreen Adapter at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 25th, 2007, 06:24 PM   #1
Widescreen Adapter
Does anyone think that this will be good for the gl2 is delivering a better widescreen image?
Also, why is this cheaper than the other really expensive wide angle lens?
http://cgi.ebay.com/45x-Wide-Angle-H...QQcmdZViewItem
Thnx,
~Tatsuya
Cameras: Canon GL-2, Panasonic GS-180
Tatsuya Graham is offline   Reply With Quote
Old May 26th, 2007, 05:29 AM   #2
The item you are referencing is a wide angle adapter--it is not a widescreen lens.
You get what you pay for when it comes to wide angle adapters for your video camera.
I would avoid no name brands.
If you want true widescreen for you GL-1, look around a for a used anamorphic 16:9 squeeze lens from Century Optics.
You get a true widescreen image *and* a wider angle of view at the same time.
John C. Chu is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
