Counter balancing adjustment Vision Blue at DVinfo.net
Old July 19th, 2011, 09:26 AM   #1
I have a Vision Blue, and concerned about leaving the counter balance adjusted. What I mean is that as I understand the mechanism it is a spring. Will leaving it in the same 'adjusted' position weaken the spring, meaning that when not in use the tension should be backed off. It doesn't mention this point in the manual. What is the skinny?>
Thks in advance.
Gary
Gary Badgley is offline   Reply With Quote
Old July 19th, 2011, 12:43 PM   #2
Images: 18
Re: Counter balancing adjustment Vision Blue
Think that's a question for Vintens very own "Action Man" - Peter.Harman@VitecGroup.com
He may well pick up his Bat Phone, having seen your post (he's a member here) else fire him a mail direct.
CS
Old July 19th, 2011, 02:04 PM   #3
Hmmm... I worked on the principle that if it doesn't specifically say not to do it in the manual, it's probably OK.
But it would be nice to get confirmation.
Old July 20th, 2011, 02:05 AM   #4
It will be fine wherever you leave the counterbalance set. The design wont allow the spring to take a set. Dont worry.
Peter Harman
Head of Global Product & Sales Training, Vitec Videocom Ltd.
Peter Harman is offline   Reply
